It is currently Fri Jan 19, 2018 9:18 pm
PostPosted: Wed Dec 23, 2009 11:52 am
Year and Trim: Dark Green 1997 SSEi
I was thinking of buying one of them when I go to Walmart tonight. A bottle of Seafoam is jacked up to $8.97 ($9.58 at oreillys!) and a bottle of Lucas is $4.58.
What should I get?
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
PostPosted: Wed Dec 23, 2009 12:07 pm
Neither. Or flip a coin, they're both good products. In all honesty, that type of product will do little for any car running decent quality fuel. Modern fuel has more than enough detergents to prevent buildup and poor spray patterns. Both of my cars proved this at 125,000 miles when my injectors were pulled and tested. And fuelinjent (member here) will tell you the same thing. If you want to run something, try toluene (or tolulene depending on manufacturer's spelling). This is THOUGHT to be a good-quality solvent for this purpose. Put one gallon into a full gallon of gas. It'll raise your octane a couple points too. Bear in mind I've spent many long hours working on fuel injectors with Chris, and learned quite a bit while I was at it.
If you're going to use off-the-shelf injector cleaner, use a name brand and don't waste your money more than once a year. $10 once a year should suffice for your peace of mind.
PostPosted: Wed Dec 23, 2009 12:16 pm
Year and Trim: 2012 Eco
I'd use the Lucas as an upper cylinder lubricant instead of a fuel injector cleaner. If you're going for cleaning the piston tops and whatnot, Chevron Techron Concentrate, Gumout Regane, Redline SI-1, or Amsoil PI will do the job very nicely. They all have polyether amines (IIRC) or PEA, which helps any carbon accumulations in the cylinders or on the valves burn off. I've noticed a difference every 10-15k miles when I've tossed a bottle onto half a tank of gas.
There are no new unread posts for this topic. fuel injector cleaner
nicklikesmilk
Sun Mar 01, 2009 9:26 pm
There are no new unread posts for this topic. Advice on seafoam fuel additive, not the air intake one
ricosuave420
Mon Dec 30, 2013 7:40 am
DaMaroon View the latest post
There are no new unread posts for this topic. After much consideration... (Thanks to Will and Lucas)
99BonnevilleSE
Tue Sep 27, 2011 10:05 pm
There are no new unread posts for this topic. Lucas Heavy Duty Oil Stabilizer
Marmot
20
2429
Sat Nov 08, 2008 1:06 pm
JMH1950 View the latest post
There are no new unread posts for this topic. Lucas heavy duty engine oil additive question
ricosuave420
21
1957
Mon Mar 04, 2013 6:44 pm
