It is currently Fri Jan 19, 2018 9:22 pm
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Thu Apr 02, 2009 4:47 pm
Year and Trim: 1997 SE 40th anniversary
We bought our 97 Bonneville SE in Nov. 98. it had the 40th annv. badges and floor mats,( we bought it from a private party with 18k miles) but now after some research it seems like it's not a 40th after all. It does not have Y40 in the vin no. which I read on a bonneville forum that, that's one of the ways to tell if you have a 40th or not.
Does anyone have anymore info on this? I would appreciate any input.
Thank you. Jaime.
PostPosted: Thu Apr 02, 2009 4:59 pm
If it doesn't have Y40 in the VIN, its not a 40th edition. Whoever you bought it from must have put them on it. I'm 99% sure that they all have Y40 in the VIN.
-Tom
2003 Silverado Ext. Cab - Charcoal - 128,000 miles - Stock...for now.
2000 SSEi - Gone, but not forgotten.
PostPosted: Thu Apr 02, 2009 5:12 pm
Year and Trim: 01 Buick LeSabre
The VIN wont be different...
The Y40 is an RPO code. Check your spare tire cover, there will be a small sticker with a bunch of three digit codes, Y40 should be on there...
- Robb -
Supercharged 2001 Buick LeSabre
1992 Pontiac Bonneville SE | Pics | Long Gone
PostPosted: Thu Apr 02, 2009 5:19 pm
http://www.bonnevilleforum.net/
According to that they do.
EDIT I guess I can't link to bonneville forum. Maybe someone with a 40th can confirm.
Quote:
40th Anniversary Edition: In 1997 Pontiac made six models: the SE, the 40th Anniversary SE, the SSE, the 40th Anniversary SSE, the SSEi, and the 40th Anniversary SSEi. The 40th Anniversary SSEi is the rarest model with a total production of 637 units. The 40th anniversary models all had a VIN with Y40—sorry guys, no fakes allowed.
-Tom
PostPosted: Thu Apr 02, 2009 5:23 pm
Robb is correct, it on the RPO codes, check your trunk.
and while your there you may as well know what the rest of those codes mean :)
found in our techinfo section http://www.pontiacbonnevilleclub.com/fo ... f=39&t=793
PostPosted: Thu Apr 02, 2009 5:27 pm
Ok, I just realized that the info I was looking at there is in the Techinfo here too.
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=39&t=1672
If it is indeed the RPO, then that info is misleading, and should be changed.
-Tom
PostPosted: Thu Apr 02, 2009 5:30 pm
I was just reading the same info Tom :)
Ok will someone with a 40th please confirm :)
PostPosted: Thu Apr 02, 2009 5:32 pm
My guess is it's in both, because Y40 is also listed in the RPO codes like you said.
-Tom
PostPosted: Thu Apr 02, 2009 9:18 pm
Year and Trim: Dark Green 1997 SSEi
Y40 will def. be on the spare tire cover. Owning one myself (and the rarest one) :).
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
PostPosted: Thu Apr 02, 2009 9:21 pm
Can you also verify if its in the VIN or not?
-Tom
PostPosted: Thu Apr 02, 2009 9:26 pm
Year and Trim: Sapphire -1999 SSEi Metallic Navy Blue
The Y40 won't be in the vin.
Here's the VIN from a 40th that's on eBay
Quote:
-G2HZ5210VH26084-
first and last #'s removed
fuelforthesoul1999 wrote:
Sapphire, of course, god that's the automobile equivalent of Halle Berry, you just want her.......
Quote:
Without question, the greatest invention in the history of mankind is beer. Oh, I grant you the wheel was also a fine invention, but the wheel does not go nearly as well with BBQ!!
PostPosted: Thu Apr 02, 2009 9:39 pm
Quote:
-G2HZ5210VH26084-
If that's the case, then the Techinfo article should be changed. I'd like someone who has Y40 in the RPO codes, to tell us if its also in the VIN or not. It makes sense that it wouldn't be, the only reason I think it is is because thats what I've read.
-Tom
PostPosted: Thu Apr 02, 2009 9:45 pm
I found a few on Carsoup that you can see the badges in, and none of them have it in the VIN. You guys are probably right, I've had false info put into my head! haha.
-Tom
PostPosted: Thu Apr 02, 2009 10:36 pm
Year and Trim: ____
There wouldn't be place in the vin for it anyways with the way GM VINs are laid out....hopefully this helps.
Viper, since you seem the type that needs to be informed correctly as you like to give advice...I'll tell you exactly what I mean.
Decoding a GM car vin was very easy to do until recently. I can't for the life of me figure out my truck's VIN the way I can an 86+ model GM car.
for example, a 1989 Pontiac Bonneville LE, 1G2HX54CXKW555555
1 - Country (US)
G - Company (General Motors)
2 - Marque (Pontiac)
H - Body Designation
X - Trim (LE) (the H and X together after 2 means Bonneville, since its the only Pontiac H vehicle. Y and Z is SSE and SE)
5 - 4 Door Sedan
4 - Restraints (Automatic Belts)
C - Engine, (LN3)
X - Check Digit
K - Model Year (1989)
W - Assembly (Willow Run, MI)
5 - Serial
5 - Serial
5 - Serial
5 - Serial
5 - Serial
5 - Serial
Therefore, a normal 1997 Pontiac Bonneville SSEi 40th Anniversary would look similar to this
1G2HZ521XVH555555, United States, General Motors, Pontiac, Bonneville SSE/SSEi, Sedan, Dual Frontal Air Bags w/ Auto Belts, L67 Supercharged 3800 Engine, Check digit, 1997 Model Year, Built in Flint, MI, and its 6 digit production Serial.
Most of the important parts of this are from memory, so if any of that is seriously off base, (it happens hah) someone let me know so more wrong info doesn't get spread.
John
PostPosted: Thu Apr 02, 2009 10:49 pm
Thanks for the info. You are right I do like to help out when I can, but I am very cautious to not to give incorrect information. I knew there was some format to the VINs I just didn't know what it was, so therefore I didnt know if there was a way it could be included or not. That makes a lot of sense to me now, the only thing I knew before was that a 1 in the 8th spot was supercharged.
To the OP: Looks like the verdict is to check you RPO's for Y40!
-Tom
PostPosted: Fri Apr 03, 2009 10:15 am
Thanks to all who responded. I looked at the spare tire cover, and sure enough, Y40 is on the sticker. So I guess we have a 40th after all. My wife will be pleased, she's the one that picked out the car.
Thanks, Jaime. :beerchug:
PostPosted: Fri Apr 03, 2009 12:31 pm
Year and Trim: 01 Buick Century Limited
10 Toyota Avalon XLS
My VIN doesn't have Y40 in my 40th either.
PostPosted: Fri Apr 03, 2009 4:44 pm
The SE and SLE Trims for 93-99 use the 1G2HX52 Vin Designation... If you have a real 40th, it will have Y40 Listed on the RPO sticker.. The Y40 is the same for the SSE and SSEi and will be listed in the RPO's..
Don't get me started on the SLE Package... :P
PostPosted: Wed Apr 08, 2009 12:47 am
Year and Trim: 1997 SSE 40th Anniversary
As someone who has a 40th its only listed on the RPO sticker, not on the VIN. The VIN doesn't take into account the added package.
Welcome though to the 40th club! Theres not many of us, but a few.
1997 SSE 40th Aniv. Dark Cherry Met., 35% tint all around, Chrome T-Stars, stock everything else
There are no new unread posts for this topic. Bonneville 40th anniversary
Bonnevillans
Mon Feb 09, 2009 12:44 am
Bonnevillans View the latest post
There are no new unread posts for this topic. 40th anniversary bonneville
chrs45
Mon Sep 26, 2011 8:17 pm
There are no new unread posts for this topic. Attachment(s) To owners of a badged 40th anniversary Bonneville
SSEiMan01
Sun Oct 09, 2011 11:23 am
reb View the latest post
There are no new unread posts for this topic. 97 bonneville ssei 40th anniversary edition
97 bonneville ssei
Fri Nov 11, 2011 8:24 pm
Bugsi View the latest post
There are no new unread posts for this topic. 40th Anniversary
Mac077
Wed Feb 18, 2009 2:39 am
Blown93SSEi View the latest post
