It is currently Thu Apr 19, 2018 1:18 pm
PostPosted: Fri Aug 05, 2011 9:38 am
Year and Trim: 1998 Bonneville SE
1985 S10 Blazer
I have a 1998 Bonneville with a 3.8L. I went outside to start my car and all it was doing was rolling over. Finally 5 hours later I tryed again and it started up. I shut it off and tryed to restart but now it will not even roll over. I got the test light out and the whole top half of the fuse box is dead. The top consist of fuel pump ignition reverse lights blinkers. (None of these work). The bottom half of the fuse box works like radio & headlights. I checked all the grounds, put cables from negative post to metal on the motor and nothing. I checked battery cables. I rolled the car over with a screw driver on the starter and that worked. ??????
[img]Doc.25[/img]
PostPosted: Fri Aug 05, 2011 1:42 pm
Year and Trim: 99 SE
99 Suburban 2500 LT
68 Beetle
By checked, do you mean the wiggle test? Or did you check the cables themselves, they have been known to corrode under the insulation of the wire.
Do you have power at the main power distribution center under the hood?
1999 Bonneville SE with the heart of a 07 Grand Prix
PostPosted: Fri Aug 05, 2011 2:12 pm
1985 S10 Blazer
I got a test light out and tested everything. I will have to check down in the insulation. I was told by a fellow co-worker to check my fuseable links, the ones on the battery, starter and on the fire wall. I am at work right now so can not go check.
[img]Doc.25[/img]
PostPosted: Wed Aug 10, 2011 5:20 pm
Check the fuses in the Maxifuse relay center... I have seen a few of these pop in the past on different H bodies... Look at the 60 amp ones first...
PostPosted: Thu Aug 11, 2011 2:25 pm
1985 S10 Blazer
I checked all the fuses under the hood I was told to check the fuseable link on the transmission.
I have not tested that yet.
[img]Doc.25[/img]
PostPosted: Fri Aug 19, 2011 8:53 am
1985 S10 Blazer
I figured out that i tap the ignition switch and I get all power back then I tap again and lose power again.(not the key switch, the one on the colum under the dash). I am going to replace this switch today and se if everything comes back.
[img]Doc.25[/img]
PostPosted: Mon Aug 22, 2011 11:45 am
1985 S10 Blazer
The ignition switch fixed all my problems and it is good to go now.
[img]Doc.25[/img]
PostPosted: Mon Aug 22, 2011 1:53 pm
Glad to hear it.... This will be one to remember.. Not exactly a common failure on the H bodies..
There are no new unread posts for this topic. 91 Bonneville SSE A/C fuse keeps blowing
Scripttester2
Sun Mar 29, 2015 6:22 am
rustyroger View the latest post
There are no new unread posts for this topic. 2003 pontiac bonneville se fuse box and relay problems! help
tom4221
Wed Sep 29, 2010 11:29 am
There are no new unread posts for this topic. Rear Fuse Box (finding a certain fuse)
JoeK
Thu Apr 26, 2012 9:17 pm
JoeK View the latest post
This topic is locked, you cannot edit posts or make further replies. Change the HUD MPH to KMH on 1998 Bonneville
snira
Tue Nov 01, 2011 3:57 pm
There are no new unread posts for this topic. 1998 Bonneville SE instrument cluster lights not working
Mike1998
Sat Sep 14, 2013 9:40 pm
GotBonneBWitMe View the latest post
