i'm ordering H.I.D kits for my high and low beams. i'm also getting angel eye fogs. i want to wire the angel eyes to the stock fog switch (the easy part) then i want to wire up a relay so when i turn on my high beams that my regular fog lights come on....
How the hell do i go about doing this
thanks
2006 Crown Vic, white P71 interceptor. Push bar, 35% tint.
TRADED IN! 2008 G8 Ignition Orange Metallic LY7, 47k miles, Flowmasters, all options but sunroof.
If you live in an area with any population, the HID highs are a bit of a waste IMO. The reason is that switching between low and high beams regularly will kill the HID's quickly, as they reignite all the time. And using high beams for more than a minute or two is hard to do. But that's me living on the densely populated east coast saying this.
You could live way far away from everybody and do all your night driving with high beams, in which case the HID highs are a good idea.
Having more light in front of the car decreases your vision far down the road. It defeats the purpose of high beams to have them coupled with fogs.
I'd run 3 relays. One relay each to the low beams and high beams since the relays for the low beams and high beams can be set up as separate circuits without ill effect. Then another relay for the fog lights. I'd also look into making the foglights operate independently of the headlights. The relay harnesses I'd use are about $10 each on Ebay. They'll come with the right connectors for your headlights and fogs.
I've driven in rural Wisconsin. Keep running with the idea!
