It is currently Thu Apr 19, 2018 1:32 pm
PostPosted: Thu May 26, 2011 6:53 pm
Year and Trim: '91 Olds 98 Regency Elite
'88 Bonneville
Battery died today....when I went to open the hood the release cable broke off just at the hold down point. I pulled off the grill and the secondary safety release. I see the back side of the hood release, but there is nothing to activated the release, and not much room for a hand or arm to get to it. All the bolts are, of course, facing the firewall-----what now...my only thought now is to hack saw off the hold down mechanism and head to the junk yard.----Any other thougths first before I do so, or anyone had this problem. First time in my life I've dealt with a problem of this nature.
PostPosted: Thu May 26, 2011 9:22 pm
This is a good one. I am sure it has happened to someone before, but I am not sure how to tackle it. I just looked at my 89 Bonneville and here is a picture of the latch and cable connection:
The space to work in:
The latch is mounted between the AC condenser and radiator with only a couple inches between. To top that off, the mount underneath is a solid plate with a few drain holes.
I have no idea how to get to it. This makes me want to inspect mine real well.
PostPosted: Thu May 26, 2011 10:16 pm
'88 Bonneville
AH HA! I got it.....I got a coat hanger and put a small hook at the end, then began to "fish" around the back side of the latch---I had to take grill off etc.....etc..... Then after about 30 seconds I was able to hook onto something and pull....and the hood popped open. I then wrapped the end of the coat hanger around the latch lever and the other end of the coathanger thru the slats in the grill.....this now is a temporary fix until I can get a replacement cable.
PostPosted: Thu May 26, 2011 10:18 pm
I am glad you got it.
PostPosted: Thu May 26, 2011 10:26 pm
what ever works right? :dontknow:
glad ya got it! :beerchug:
Wake asked SSEiman01 wrote:
why in the the world do you have or need Vaseline in your trunk??!!..well Leather cleans easy..
There are no new unread posts for this topic. 90 SSE Hood release cable broken
tomp
Fri Oct 22, 2010 8:45 am
tomp View the latest post
There are no new unread posts for this topic. E-Brake Release
Ol' Timer
Wed Nov 26, 2008 4:43 pm
Ol' Timer View the latest post
There are no new unread posts for this topic. Trunk release suddenly not working...
Z-type
Sun Dec 07, 2008 4:00 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. emergency fuel door release?
tpulliam79
Tue Mar 20, 2012 3:52 pm
There are no new unread posts for this topic. help, broken water pump bolts in the engine.
88bonnsse
Thu Apr 07, 2011 9:06 pm
willwren View the latest post
