It is currently Tue Jun 19, 2018 8:01 am
PostPosted: Sun May 25, 2008 3:27 am
Year and Trim: 1996SSEI
Can anyone tell me what the normal running temp is for 1996SSEI.Mine gets to 220 or so,then sometimes drops back somewhat.Just got a rebuilt engine in my baby,and before I got the new engine,when temp went to 220 or a little more,check gauges light come on,and bell sounded. I smelled antifreeze.Just got car back last week and am still paranoid,and still waiting for that check gauges bell to come on again.I never wanna hear that sound EVER AGAIN!!!I guess I just want to know if that temp is normal?????? Thanks in advance,Lisa
PostPosted: Sun May 25, 2008 6:42 am
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
your car stock has a 195 degree thermistat. Your guage in the dash is not acurate, the only way to tell for sure is to have a scanner on the car and monitor the coolent temps. If you are getting "wild" swings in coolent temp you more than likely have an air bubble in the coolent. It could even be a "lazy" thermistat. Have whoever did the engine to run it with a scanner to tell for sure.
PostPosted: Sun May 25, 2008 7:15 am
Supercharged engines typically run hotter than NA ones, but there are things you can do to help keep its cool.
Like was said already, you may have a few bubbles in the coolant system. The easiest way to bleed them out is to go buy a radiator cap with the lever on it (to release pressure before opening the cap), and install it. After a good drive, open up the hood, and pull on that lever to "burp" it. Do this several times as you won't get all the bubbles out the first time.
Another thing you can do is to bypass the transmission cooler inside the radiator completely and go with a larger aftermarket external cooler. This will not only help the transmission run cooler, but will help it last longer as well.
The cheapest thing to do, however, is to do a mod known as a fan override. This mod allows you to turn the fans on when YOU want them to, instead of when the PCM THINKS they should be on. I think it can be done in such a way as to not set off a code...someone else could chime in on that. But in any event, change out that thermostat to a 180*.
BonneMe wrote:
PostPosted: Sun May 25, 2008 8:55 am
Hi Lisa,
A one-time burp of air in the coolant circuit can lead to an over-heat like you just saw (actually, the car really didn't overheat, the air/steam bubble just went past the temp sensor on the intake manifold and the car saw a spike in temp.)
So long as the coolant levels hold stead and the car doesn't repeatedly over-heat, then it's fine. Periodicaly check the level in the radiator when the car is cold, along with the overflow jug. Radiator should be full all the way to the cap, jug filled to the line on the side. It should remain that way for months. If it does, you are not loosing coolant somewhere.
The 195 thermostat sets the minimum operating temp..it's the temp the valve opens at to allow coolant to flow to the radiator. It's not really the actual operating temp the motor will run at, especially now that summer is here and the AC gets more use.
PostPosted: Sun May 25, 2008 11:17 pm
Year and Trim: '94 Bonneville SE
'93 Bonneville SSEi
My 93 SSEi would show a little over 200 on the factory gauge. I replaced the stock thermostat with a 180. Now the gauge reads below 200 consistently.
As for manual fan control, yes you can tie into the fan relay and turn the fans on when you want. I think you have to tie into the high speed relay. I think I heard somewhere on the forum that if you tie into the low speed, you may throw a code. I only tied into the high speed.
1994 Bonneville SE
1993 Bonneville SSEi
1972 LS5 454 Impala Convertible
2005 Mustang GT
Impala Webpage http://www.trainweb.org/indcentral/Car%20Page2.htm
PostPosted: Mon May 26, 2008 3:15 am
Thanks for all the info,I really appriciate it!
There are no new unread posts for this topic. is this the normal running temp
razmatazz
Wed Jan 11, 2012 12:24 pm
There are no new unread posts for this topic. Heat? Flashing Temp? Cabin Temp Sensing? ECC Issues!
wjcollier07
14
7296
Mon May 24, 2010 11:01 pm
wjcollier07 View the latest post
There are no new unread posts for this topic. Engine won't reach higher rpm
ladyoftheflies
Tue Apr 22, 2014 11:46 am
MurderMitten View the latest post
There are no new unread posts for this topic. Is this normal???
PLAGUE PHANTOM
Sat Feb 25, 2012 8:28 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 93 SE - ABS Activating upon normal braking
wjcollier07
14
1811
Sun Aug 31, 2008 7:17 pm
willwren View the latest post
cron
