It is currently Tue Apr 16, 2024 1:56 pm
PostPosted: Wed Jan 04, 2012 8:30 pm
Year and Trim: 1998 bonneville se
my 98 bonneville se will shut off while driving for some reason. after coasting to a stop you can turn the key on and when you hear the fuel pump come on and prime you can crank it and drive on. sometimes it may take turning the key 10 20 times until you hear the full pump before it will crank. i have changed the fuel filter thinking it may be stopped up and it still has the problem. there was a time that i was powering the window up when the car died and the window lossed power also, but then begain to roll up again. can someone tell me anything about this problem. any help would be nice... thank you............................
PostPosted: Wed Jan 04, 2012 10:52 pm
Unhook your battery, clean any corrosion from the ends (peel back the rubber covers and clean in there too), then retighten them (don't over do it, they can strip out), and try again.
PostPosted: Wed Jan 04, 2012 11:08 pm
Year and Trim: 99 SSEi
99.999 percent chance it's a corroded ground bus on the driver's side.
2006 Chevy Monte Carlo SS
PostPosted: Fri Jan 06, 2012 10:29 am
Year and Trim: 1988 sse - 80,000 on the clock and my first car...
1995 se wit da sle package- 120,000 on the clock and ticking stronger then ever...
my 88 bonneville had the same symptoms you are getting and my problem was a bad torque converter clutch in the transmission. all i did was unplug and the car stayed running fine. gave me less gas millage but atleast the car stood running
PostPosted: Fri Jan 06, 2012 12:11 pm
88, that isn't going to work on any car 92 or newer. That's not a fix, either.
Chances are near 100% that it's the driver or passenger side ground bus, or the battery cables themselves. Go after all 3.
PostPosted: Wed Nov 27, 2013 7:24 pm
Year and Trim: 1999 Pontiac Bonneville SE
My car has been sitting up for several months while I've been out of state on a job. When I got home the other day, the car would crank & run for just a few seconds and then die. I figured plugged fuel filter because fuel pressure didn't seem high enough. That didn't help. That's when I noticed that power windows wouldn't work and the power seat would just click. I checked the cables, battery and grounding, and everything checked out OK. That's when I came across this forum and discovered there's a grounding buss by the driver's door. It took less than 10 minutes to access it, clean the corrosion off and replace the trim. Everything's working OK now.
My thanks to you guys for identifying this problem and easy fix!
Terry
PostPosted: Thu Jan 12, 2017 8:32 pm
Year and Trim: 1997 se
never mind wrong spot
PostPosted: Fri Jan 20, 2017 8:13 pm
05 Mercedes S500 4Matic
Holy thread necrophilia, Batman!
Don't raise someone else's old thread from the grave to ask about your own car's new problem.
Please start a new thread with your car's problem.
`05 Mercedes S500
There are no new unread posts for this topic. 1999 Bonnie shuts down for no reason
cliff123
Wed Aug 26, 2009 1:58 pm
Troyport View the latest post
There are no new unread posts for this topic. Car shuts off while driving
Manbear
19
7610
Thu Mar 24, 2016 12:39 am
chevrolet.power.420 View the latest post
There are no new unread posts for this topic. Randomly shuts off
emberg89
Fri Jan 23, 2015 7:05 pm
There are no new unread posts for this topic. starts and shuts off
95bonneville
Wed Nov 02, 2011 3:36 pm
95bonneville View the latest post
There are no new unread posts for this topic. Car Shuts off while driving???
BM3MW
16
8669
Wed Dec 07, 2011 8:05 pm
RPACODY View the latest post
