It is currently Thu Apr 19, 2018 1:32 pm
PostPosted: Sun Jul 04, 2010 8:53 pm
Year and Trim: 1995 Bonneville SSEi
1992 Bonneville SSEi - RIP
I'm having problems getting 1 of the 4 long bolts out on the water pump and I cant remember how I did it last time.
The problem I'm having is the support bracket for the Altenator, Power Steering pump and the Tensioner is covering one of the Water pump bolts.
Here is a pic of the bolt thats giving me a hard time.
I checked Mitchell and Haynes manuals but they are of no help. They just show the non-SC engines.
I really don't want to have to take off all the stuff I mentioned above for one bolt on the pump.
Anyone know a short cut or trick ???
Thanks in advance,
Dutch
92 SSEi
PostPosted: Mon Jul 05, 2010 8:35 am
Two choices:
Remove the accessory bracket.
Dremel.
Yeah, I know, it sucks.
PostPosted: Mon Jul 05, 2010 1:01 pm
Thanks for the response, thats what I figured :wink:
I'm just trying to avoid doing all the extra work, taking off all that extra crap for one stupid bolt.
I was thinking of dremeling the bracket just enough to allow a socket to fit over the bolt head.
Do you know what the difference is (Material) between the Felpro gasket and the standard one for the Water Pump ?
Thanks again,
Dutch
92 SSEi
PostPosted: Tue Jul 06, 2010 1:13 am
I've had good luck with the blue plastic Felpro gasket. No leaks, and if you take the pump off, there's no gasket to srape off.
PostPosted: Wed Jul 07, 2010 4:33 pm
Year and Trim: 1993 Pontiac Bonneville ssei
Having worked on a lot of equipment involving gaskets, go with the Felpro just in case you ever have to do it again.
PostPosted: Wed Jul 14, 2010 12:54 am
I recently had to do the same thing. I just took off the whole bracket just to make sure that everything was tight.
good luck
PostPosted: Wed Jul 14, 2010 10:18 am
The bracket doesn't have to come completely off. Just loosen it enough to be able to move it around.
PostPosted: Sun Sep 05, 2010 6:01 pm
Year and Trim: 1993 Pontiac Bonneville SSE 153K miles
Appears to me the water pump on the 93 SSE is about the same as the 92. The instructions I have in the shop manual shows removing the accessory bracket, but also removing the engine mount. How difficult was removing the engine mount and reconnecting it afterwards? To me that part sounds more intimidating than the accessory bracket. My water pump has lasted 175K miles, so I am thinking I may want to replace it before it quits on its own. When (how many miles) did you have to replace yours? My engine temp reads between 200/210 usually, unless I am stuck in traffic--then it creeps up to 215/220 level fairly quickly, especially here in south Texas where the temps are sometimes 100+ along I-10.
PostPosted: Sun Sep 05, 2010 7:45 pm
You cannot predict the failure of a water pump based on miles, nor can you base it on average engine temps. The failure mode has nothing to do with either.
Your water pump will fail when one of these happens:
1. The seal for the bearing ruptures, and coolant leaks out the weep hole.
2. The bearing cooks itself making really cool noises.
3. The shaft shears off and stops pumping coolant.
#1 is the most common. It gives a nice visual indication you need to do something, and the warning usually comes before it gets critical.
PostPosted: Mon Sep 06, 2010 10:22 am
Thanks for the tips, Willwren, I will watch for any of those clues. Any tips for removing that engine mount? And if/when I do replace the water pump, any suggestions for which brand pump to put back in?
PostPosted: Mon Sep 06, 2010 10:42 am
Buy the AC Delco pump from http://www.rockauto.com and use our club discount listed in General Chat. The AC Delco pump for the Series 1 is a cast-impeller superior design to the Series 2 stamped pump (and should be considered by any S2 owner for conversion, you just have to use the S1 water pump pulley with it).
To remove the mount, you need to jack the motor with a block of wood to support the oil pan. Lift the load off it, then remove the long bolt running through the mount. You may want to disconnect from the frame AND motor to make it easier, but it's the piece on the motor you need out of the way. Those bolts (3 of them) will be very tight, and the studs are long, which is why you may find it easier to remove the bolts on the subframe half of the mount as well.
Inspect the knuckle half of the mount when you have it out. If you see cracks, replace it. This is an oil-filled mount designed to dampen engine vibrations.
PostPosted: Mon Sep 06, 2010 10:56 am
Thanks again for the tips, Willwren. I will check out that discount on Rockauto, and examine the mount knuckle too. Hard to find that type of practical information in the book.
There are no new unread posts for this topic. 93 SSEi Water Pump R/R
londonontman
Fri Mar 13, 2009 10:25 am
londonontman View the latest post
There are no new unread posts for this topic. 98 SSEI water pump
CatmanFS
Mon Mar 17, 2014 11:24 am
CatmanFS View the latest post
There are no new unread posts for this topic. 94 SSEi Water Pump
2000Silverbullet
Tue Sep 30, 2014 11:55 am
There are no new unread posts for this topic. 1998 ssei water pump
trf_ssei
Fri Oct 31, 2008 7:18 pm
trf_ssei View the latest post
There are no new unread posts for this topic. 1998 SSEi water pump
z28maro91
Tue Jul 24, 2012 1:27 pm
z28maro91 View the latest post
