It is currently Wed May 22, 2013 2:09 pm
PostPosted: Sat Jun 05, 2010 3:03 pm
Year and Trim: 92 Bonneville SE
I have a 92 Bonneville SE and I need a diagram of the maxi fuse relay center. Not so much the fuses, because they are labeled, but I really need to know which relay is which. Specifically the fuel pump relay, as I am having issues with my fuel system. Any help would be greatly appreciated! I have scoured the internet and cannot seem to find any sort of diagram or even information on which relay it is. Thank you
PostPosted: Sat Jun 05, 2010 3:53 pm
The fuel pump relay is actually in the block behind/to the right of the glovebox. Relay 2, second from the top in the right hand column. It's fuse is number 6 in the same block.
Have you tried the fuel pump prime lead? It's the empty connector above the battery. Run a wire from the positive terminal to the lead and see if the pump runs.
WHITE WHINE - IT'S INTOXICATING. 1992 SSE Supercharged 236.26 ci
15.090 at 90.2 MPH with a slipping tranny and a melted O2 sensor - Mods made me slower.
2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, SLP Intake, autodim Trailblazer mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter, GXP rear sway bar
ADMIN http://www.pontiacbonnevilleclub.com
This site is made possible by the intellectual contributions of the Pontiac Bonneville Community as a whole. Our ad-free environment makes it plain to see that we are here to help the community, and nothing more. We will never try to sell you ad-free surfing, or access to hidden forums with 18+ content, or sell your email address. We are not here to profit from you.
PostPosted: Sat Jun 05, 2010 6:19 pm
Year and Trim: 98 LeSabre Limited, 2003 Lesabre Limited
This is a 1993, I believe. The fuel pump is fourth item from top on left side.
The diagram for the relays and fuses is on top of the hush panel you take off to get access to the underdash panel on the passenger side like J Wikoff said.
PostPosted: Sat Jun 05, 2010 6:46 pm
There were differences between 92 and 93. Go with Wikoff's guide.
PostPosted: Sat Jun 05, 2010 10:51 pm
Here's the page from my 92 FSM.
PostPosted: Sun Jul 18, 2010 12:42 am
Year and Trim: 1993 bonneville se
I also need this information. my son just bought an 93 that cuts off after it runs for a little while. when this happens the 3rd relay from the left starts to buzz. I have tried swaping the relay with another on and get the same problem. I have look all over for a diagram to see what this relay is but cannot find it. something that might be related before i swapped the relay his tac and speedometer were not reading right the speedometer read 50mph when the car was parked. swaping this relay fixed that problem. This relay has a red,tan,black/white, and blue wire. looking at the wire diagram from a hayes manual and one I downloaded off of Autozones webb page I cannot find any relay with those colors. Any ideas?
thanks
There are no new unread posts for this topic. maxi/relay center diagram needed for a 1994 pontiac bonnevil
zimmie
Thu Aug 11, 2011 10:57 am
gmman View the latest post
There are no new unread posts for this topic. Fuse cover diagram
hotwheels29
Thu Apr 30, 2009 10:10 pm
hotwheels29 View the latest post
There are no new unread posts for this topic. 93 bonnie SSEi fuse diagram
smithd2424
Sat Feb 06, 2010 1:57 am
J Wikoff View the latest post
There are no new unread posts for this topic. how to access passenger side relay/fuse panel
Billha
Sun Apr 05, 2009 8:24 pm
92BonnevilleSE View the latest post
There are no new unread posts for this topic. relay center
mckcuzzi
Fri May 27, 2011 4:59 pm
sandrock View the latest post
Users browsing this forum: Google [Bot] and 4 guests
