It is currently Thu Apr 19, 2018 1:33 pm
 Post subject: 1999 SSEI Exhuast Tip
PostPosted: Fri Jun 04, 2010 3:53 pm
Year and Trim: 1999 Pontiac Bonneville SSEI
Greetings, Bonneville experts!
Some how my 1999 SSEI exhaust tip disappeared, it must have fallen off. I could not find OEM part. What is the part #? please.
What is the next best thing you would recommend. What is the inlet diameter, any catches?
Thank!!!'
Bill
PostPosted: Sat Jun 05, 2010 10:24 pm
Year and Trim: 1994 SSE - Sold
1999 SSE - Sold
2005 GXP - Driving
If it is the same as the SSE it ought to be 25625048. I bought one January of '09 listing at $35.86. I had bought on for the other side in Nov of '07 and was listing at $29.87. Part was same for both sides unlike my '94 SSE.
I was able to re-use the clamps - I needed LOTS of PB Blaster to bet the hardware loose, then had to "stretch" the exhaust pipe an expander top open it enough to allow the replacement tip to be installed.
-Bob
Bonneville History.
1979 Maroon two-tone (sure miss those fender skirts) with the whorehouse red interior - given to my sister then she wrecked it
1994 SSE green Sold
1999 SSE white Sold, but I still see it on the road from time to time
2005 GXP white tri-coat Daily Driver
PostPosted: Sat Jun 05, 2010 10:38 pm
I wasn't able to source OEM tips for the 94 so I installed a couple of aftermarket tips.
The outlet pipes are smaller than 2 1/4" which is about as small as you can obtain. So ya, you'll have to have an exhaust shop expand the outlet and squeeze the tips for a stitch weld on both sides. Don't worry about getting a tight fit. I can see light around mine but it's not noticeable unless you get up close. :wink:
PostPosted: Sun Jun 06, 2010 12:02 pm
Thank you very much for your help.
Bill
There are no new unread posts for this topic. 1999 bon ssei supercharged. HID kit??
michaelthibodeau
Sat May 05, 2012 3:43 am
renchjeep View the latest post
There are no new unread posts for this topic. Steering issue for 1999 SSEi
Reign
Mon Feb 25, 2013 12:15 am
There are no new unread posts for this topic. 1999 SSEi suspension issue
blye
Fri Apr 12, 2013 5:24 am
impala67 View the latest post
There are no new unread posts for this topic. Replacing Blower Control Module 1999 SSEI
nabilsalama
Sat Feb 20, 2010 8:18 pm
There are no new unread posts for this topic. 1999 A/C clutch
spydog
11
1171
Mon Sep 07, 2009 12:17 am
ron350 View the latest post
