It is currently Fri Jan 19, 2018 9:20 pm
PostPosted: Thu Mar 18, 2010 8:43 pm
Year and Trim: 2004 Volvo S60
I want to replace the sending unit. Gauge is erratic, I know this to be normal but ever since the original failed the readings have been lower than they used to be, and I feel they are higher than displayed. I'm looking to get an ACDelco unit, only place I can find it is GMPartsDirect, and the listing is as such found in the mechanical catalog:
Mechanical Catalog - 1995 - Pontiac - Bonneville
, Oil pressure sending unit, all models
I'm guessing all of ours are the same? If not can someone tell me where to acquire an ACDelco unit from?
PostPosted: Fri Apr 02, 2010 1:39 pm
Did you try RockAuto?
If you go to ACCDelco.com, you can get a list of all the vehicles that have the same part number sender.
PostPosted: Fri Apr 02, 2010 2:49 pm
They are not the same. Cars with a gauge use a different sender than cars with a dummy light only.
PostPosted: Fri Apr 02, 2010 8:17 pm
Can I possibly get a part # or place to get an ACDelco unit?
PostPosted: Fri Apr 02, 2010 9:09 pm
25627057 is the only number I can find. GMPD and Monsterparts say they have it.
PostPosted: Fri Apr 02, 2010 9:37 pm
So, is that the correct one? When I had last looked it up, there was no part # and it was very basic as I posted above. Not in any way saying you are wrong, just trying to clarify if your statement is one of saying "this is the part number" or "this is all I could find from my looking"?
PostPosted: Fri Apr 02, 2010 11:05 pm
I found it two places, and both said "all models". I'm starting to think that if there was two, they figured out that the "guage" version would work for the "just a light" version.
PostPosted: Sat Apr 03, 2010 2:43 pm
Year and Trim: 1993 SSEi
Rock auto has the ac delco unit,they list it under fuel pressure switch,
1995 PONTIAC BONNEVILLE SSE 3.8L 231cid V6 MFI Supercharged (1) OHV : Electrical-Switch & Relay : Fuel Pump Pressure Switch Price Core Total
ACDELCO Part # 25627057
SENSOR,F/PMP SW & ENG OIL PRESS GA w/GA(UB3) or GA CSTR(U2F) or GA CSTR(U50)
$58.79 $0.00 $58.79
This is the one you want,it will work for 92-99 cars with gauges.
There are no new unread posts for this topic. Oil Pressure Sending Unit, 97SE
Bugsi
Sun Dec 29, 2013 10:48 pm
Archon View the latest post
There are no new unread posts for this topic. Fuel Sending unit
tripscarcare95
Mon Sep 20, 2010 9:24 am
There are no new unread posts for this topic. fuel sending unit
monte0
Wed Apr 22, 2015 12:02 pm
monte0 View the latest post
There are no new unread posts for this topic. 97 SSEi fuel pump/sending unit
pmicaza
Thu Nov 05, 2009 2:40 pm
reb View the latest post
There are no new unread posts for this topic. melted wire on fuel pump sending unit
venom11
Wed Sep 29, 2010 3:27 pm
venom11 View the latest post
