It is currently Thu Apr 19, 2018 1:22 pm
PostPosted: Thu Nov 05, 2009 12:58 pm
Year and Trim: 1997 SSEi 40th Anniv
HI,
I am finally getting around to replacing the fuel level sending unit on my 97 SSEi, (because the gauge reads full until the tanks is empty). I figured i would also replace the fuel pump while i had the tank out as i remember this job being a pita. However, my local jobber says all these parts are dealer items and unavailable to her. The car is also throwing a P1441 and it seems that the purge valve needs replacing as well...also unavailable to the jobber. We checked the SE parts and they are available.
do i really have to get these parts from a dealer or is there another after market source?
thanks,
peter
PostPosted: Thu Nov 05, 2009 1:01 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
any auto parts store will have them
PostPosted: Thu Nov 05, 2009 1:35 pm
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
You might also check www.rockauto.com for the lowest price, plus we get a 5% discount (which basically will cover shipping) with this discount:
22360111872527
Hurry -code expires November 15th.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
PostPosted: Thu Nov 05, 2009 2:40 pm
Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner
PITA job, the parts are available aftermarket but the quality varies. You get what you pay for. Change the sensor on the tank while your at it. Mine went bad after the job was done, which trips an evap code. I just left it that way and disconnected the whole darn evap system.
There are no new unread posts for this topic. melted wire on fuel pump sending unit
venom11
Wed Sep 29, 2010 3:27 pm
venom11 View the latest post
There are no new unread posts for this topic. Fuel Sending unit
tripscarcare95
Mon Sep 20, 2010 9:24 am
There are no new unread posts for this topic. fuel sending unit
monte0
Wed Apr 22, 2015 12:02 pm
monte0 View the latest post
There are no new unread posts for this topic. Gas gauge stuck at full....new fuel sending unit???
Ludichris
16
6248
Thu Nov 18, 2010 11:17 pm
There are no new unread posts for this topic. 96 Bonneville fuel tank sending unit replacement
catalina68
Mon Jul 16, 2012 9:28 am
reb View the latest post
Users browsing this forum: 614justin and 6 guests
