It is currently Fri Jan 19, 2018 9:25 pm
Post new topic Reply to topic  [ 17 posts ]
 Post subject: Air Mix Actuator...
PostPosted: Mon Sep 07, 2009 3:45 pm
Year and Trim: 2004 Volvo S60
So,
Seems to me the actuator got stuck. A/C runs fine, massive water coming out, nothing cold coming in, it's just a neutral temperature. Adjusting the electronic climate control from 60 to 90 does absolutely nothing at all, the temperature stays the same.
Thoughts? How to fix?
 Post subject: Re: Air Mix Actuator...
PostPosted: Mon Sep 07, 2009 4:56 pm
Update: Ok, with some searching I removed the glove box and see the arm and the actuator, it's stuck, won't move. I think I see how to get to it, but now I can't find one listed anywhere in any parts stores around here...am I missing something here?
PostPosted: Mon Sep 07, 2009 5:13 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
I don't believe it will be in a parts store. JY, dealer or gmpd
PostPosted: Mon Sep 07, 2009 7:06 pm
I am having trouble getting to it...can I get some direction please?
Also, possibly a part number for GMPD?
PostPosted: Mon Sep 07, 2009 10:08 pm
Try the search feature using "air mix" as the subject - you should get a bunch of hits. willwren in the author line should bring up the redneck fix, and if you search "trialsnuts" (?) Stan has a great article with pix.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Mon Sep 07, 2009 10:21 pm
www.trialsnuts.com/ecc.pdf
PostPosted: Tue Sep 08, 2009 10:02 am
Year and Trim: 2008 Aura XE
http://www.pontiacbonnevilleclub.com/fo ... =49&t=3537
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
PostPosted: Tue Sep 08, 2009 10:32 am
Doesn't look like too fun of a job eh?
So I have to take out my ECM and get at the unit from under the dash if I am correct?
PostPosted: Tue Sep 08, 2009 11:29 am
Yes. Removing the passenger seat is almost necessary.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Tue Sep 08, 2009 1:19 pm
Luckily I'm a pretty small guy (5'7") and I have AL7's that go far back. Hopefully it'll be enough room.
PostPosted: Tue Sep 08, 2009 1:29 pm
Trust me... you are going to want to remove the seat.
-Andrew-
PostPosted: Tue Sep 08, 2009 2:41 pm
Ughhh...don't tell me that...Every time I do that I wreck something, those seats weigh like 2x me lol.
I know I have most of the details at my disposal, but can you just give me a quick list of parts needed to be removed to get to this? I see something about the a/c control unit itself? Also the accumulator is on the heater core cover and comes off with it?
PostPosted: Tue Sep 08, 2009 3:17 pm
Yes, the heater core cover is the hard part. I had to peel back the carpet and the padding to get it out
1998 Bonneville SE
1992 Bonneville SE
PostPosted: Tue Sep 08, 2009 3:51 pm
Oh, awesome. How long should this job take?
PostPosted: Tue Sep 08, 2009 3:58 pm
Year and Trim: 1993 SE
1997 SSEi 40th
I've done mine without removing the seats, just set something soft over the door sill and set something up to prop your butt and legs off to the side.
First time I did it the job took about 5 hrs, only because I had to go to Sears and get a thumb ratchet set, you are probably going to need it too to handle the screws on top of the actuator for removal/installation.
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
PostPosted: Tue Sep 08, 2009 6:35 pm
5 hours isn't bad....I am planning to give myself a full day for this.
While I am at this, my recirculator function has NEVER worked, the indicator comes on the ECC but never does a thing. Is it somewhere close where I'll be so I can combine the jobs or?
PostPosted: Sat Oct 17, 2009 5:07 pm
Unfortunately, I tried to do the work today and stopped. Getting the vacuum lines out from the HVAC alone broke a plastic clip which made me annoyed enough to realize best to pay someone else to do it, I'm not familiar with the job and don't feel like breaking things along the way, which, in the end, will make this project cost exactly the same as it would with the discounted labor rates I pay anyway. For a quick fix, I unhooked the arm from the blend door and moved it to hot so I have heat now.
There are no new unread posts for this topic. Air Mix Actuator???
jleeheat
Mon Dec 06, 2010 4:31 pm
jleeheat View the latest post
kreed
Sat Jul 14, 2012 1:00 pm
glenn304bonne97 View the latest post
There are no new unread posts for this topic. Air Mix Door Actuator P/N?
95naSTA
Wed Jun 04, 2008 12:31 pm
tpulliam79 View the latest post
There are no new unread posts for this topic. air mix actuator question
Guest
Wed Nov 05, 2008 6:28 pm
Guest View the latest post
There are no new unread posts for this topic. air mix actuator - new discovery 95 SSEi
skregal
Sun Jul 27, 2008 5:13 pm
