It is currently Fri Jan 19, 2018 9:08 pm
 Post subject: Fuel pump relay
PostPosted: Mon Aug 03, 2009 10:02 pm
Year and Trim: 1994 Bonneville SSEi Charcoal Grey
My bonnie died and its definatly the fuel pump...but i want to check the relay first being that it was raining like hell when it died......i fond them up front with the 2 little boxes that hold the maxi fuses....i found the 7 or 8 grey little blocks with the cover on them...onlyu one problem...they dont have a name or indication of which is which...so please help me out guys....which one is it starting from the left side going to the right..thanx peoplesfor the info........Felix....
 Post subject: Re: Fuel pump relay
PostPosted: Tue Aug 04, 2009 1:48 am
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
it is in the passenger side footwell, should have a diagram there also.
good pic of both left and right fuse/relay panels here
viewtopic.php?f=19&t=10605&p=111942&hilit=fuel+pump+relay#p111942
PostPosted: Tue Aug 04, 2009 12:32 pm
Year and Trim: 99 SSEi
We don't see many problems with the fuel pump relay however the fuel pump ground is a common problem. Check the driver's side ground bus for corrosion. If the ground bus is clean then check the relay & fuses before changing the pump.
2006 Chevy Monte Carlo SS
PostPosted: Tue Aug 04, 2009 12:36 pm
if your fog lamps work, you can switch that relay with the fp relay and see if the fogs work.
PostPosted: Tue Aug 04, 2009 9:48 pm
There is a test jumper behind your battery.
Apply 12v to the green connector buried back there. Do you feel/hear the relay click above your passenger footwell? Does the pump prime? Listen at the rear of the car while someone does it.
It should also click the relay and prime the pump in the tank when the ignition is turned on.
There are no new unread posts for this topic. Fuel pump relay location, '95 Olds 88, NA
57lxi
Thu May 29, 2008 6:54 pm
There are no new unread posts for this topic. changing fuel filter-need pump relay location
Need For Steve
Sun Oct 31, 2010 8:11 pm
There are no new unread posts for this topic. 1995 bonneville wont start and fuel pump relay clicking
zach
Mon Jun 15, 2009 9:50 am
There are no new unread posts for this topic. Ug, now my fuel pump is bad
Yoshicoby
Mon Sep 22, 2008 3:26 pm
GoldenBullet View the latest post
There are no new unread posts for this topic. Fuel Pump
tripscarcare95
Thu Nov 20, 2008 8:49 am
Maymybonneliveforevr View the latest post
