It is currently Thu Apr 19, 2018 1:24 pm
PostPosted: Mon Mar 09, 2009 9:55 pm
Year and Trim: 03 SE
Car shifts smoothly in all gears. Once it gets into overdrive around 45-50 car starts to jerk, buck, shake etc. Rpms are at 1500 at this mph. If we use the shifter just below overdrive it locks out overdrive and drives fine but of course RPMs soar over 2000. Fluid needs to be changed as we do not know when it was done and is not a Rosy red anymore. It doesn't smell burnt but appears to be getting old. That is my first thing to do. Would a worn CV joint cause this? We just replaced the master cylinder as it was leaking but it leaked down to the boot and melted the boot and seeped into it. Also it started all of a sudden a vibration when braking on the front drivers side wheel and a vibration when turning to the right. Started right after master cylinder change. I'll probably take back to mechanic as it might be related. We just replaced the hub bearing on that about 2K ago. Also no codes are showing. Any ideas other than a shot tranny which may be the original. :sad:
99 Oldsmobile Silhouette 229K
03 Bonneville SE 150K
05 Saturn Relay 97K
14 Chevy Malibu LS 89K
The only dumb question is the one you didn't ask.
PostPosted: Mon Mar 09, 2009 10:34 pm
You have a misfire. It's more evident in overdrive than any other gear. This is the most likely culprit. Check your plugs and wires. Pull all 6 and inspect them, it should be obvious. It's best to post a pic of them, but keep them in order so you know what came from where.
If that isn't it, we'll take it from there.
PostPosted: Mon Mar 09, 2009 10:35 pm
This is most likely an ignition problem. Check your plugs/wires/coils
EDIT: willwren and his sneaky fastness #-o
PostPosted: Mon Mar 09, 2009 11:05 pm
it will most likely be your plugs wires, i had the same exact problem.....took a while to figure it out :)
good luck
PostPosted: Tue Mar 10, 2009 8:51 am
Ok I'll check that out. Wires were replaced about 6 months ago, the second set in a little over 18 months as the last set failed and caused misfire at idle. Maybe it's a simple thing.
05 Saturn Relay 97K
PostPosted: Wed Mar 11, 2009 2:54 pm
What kind of wires were you using?
PostPosted: Wed Mar 11, 2009 4:31 pm
New set of GM wires from the dealer.
I did a preliminary check of the boots and wires and everything checks out. Next is to spray some water mist at night and see if I have arching. Then I'll pull plugs one by one. Car runs great and powerful until it hits overdrive and it will not go over 1500 RPM and speed will not increase even if the pedal is to the floor.
05 Saturn Relay 97K
PostPosted: Wed Mar 11, 2009 6:55 pm
Year and Trim: 1998 bonneville SSEi
shouldn't he check the coils as well, since hes already checkin ignition components.
PostPosted: Wed Mar 11, 2009 7:01 pm
I'm probably going to check them as well. I am a pro at checking them as I have had this misfire problem too many times but haven't had it in overdrive.
05 Saturn Relay 97K
PostPosted: Wed Mar 11, 2009 8:28 pm
Also check the fuel pressure.. And how old is the Cat ? Backpressure test maybe?
PostPosted: Wed Mar 11, 2009 10:53 pm
Cat is only about 6 months old as well. Fuel pressure should be good as we have replaced the fuel filter, fuel pump, and FPR about 2 years ago. It is just a matter of taking the car off the daughter long enough to do the tests! I haven't first hand experienced it but I will be taking the car to work on Monday as I have to drop my car off at the dealer for state inspections. I'll be sure to have my scanner with me to see the live data.
P.S.
Something just hit me. Car sat for about 2 months so it could be water condensation in the tank. I'll throw in some drygas for good measure!
05 Saturn Relay 97K
PostPosted: Fri Mar 13, 2009 2:14 am
Year and Trim: 1988 and 1987 Buick Lesabre T-Type
If not Ignition. TQ converter problem?
~~~Freddy~~~ Wyotech Graduate, Future RCSAMS student
Pandora 1988 Lesabre T-Type 259000 miles
Darlington 1987 Lesabre T-Type 115000 miles
Cream Puff 1988 Lesabre T-Type 194500 miles
PostPosted: Sat Mar 14, 2009 1:33 am
Year and Trim: 1993 SSE NON S/C 3.8 series 1
Was experiencing something similar and replaced one of the engine/trans mount. mount had "sogged" out and was allowing the engine to walk especially in overdrive after the last shift on the highway. like you said, 45-50mph
Just seems a sin to let ole Bonnie die, its like she is part of the family.
PostPosted: Sat Mar 14, 2009 4:02 pm
Well it is now doing it when overdrive is locked out (by shifter) and going 45-50. So it definitely sounds like a misfire problem. I still can't get car off daughter yet to test it. My guess is that a coil is crapping out.
05 Saturn Relay 97K
PostPosted: Sun Mar 15, 2009 8:38 am
Year and Trim: 10 Silverado
When I experienced this problem in my 95 it was the plugs, all of them for the most part. t the time my car had the original plugs still in it and was at 98K miles... some time ago. I found my plugs were at 085. After installing a new set mine was running great again. I just noticed the 94 I just got is doing this... didn't notice this when I test drove it. Plugs/Ignition is were I'm gonna start looking.
Good luck :)
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
PostPosted: Mon Mar 16, 2009 9:50 pm
Ok I had car today and here is my report. I added a can of dry gas a few days ago and this may or may not have solved this problem.
The car behaved well for me with no hesitation or bucking as my daughter explained. Trans and engine were well coordinated and plenty of power so I rule that out. I did notice something in suspension causing a shake that starts around 45-50 and fads around 55-60. To me it feels like unbalanced tires. That makes sense as we just rotated the tires and they probably haven't been done for many years. There is something going on in front driver's side suspension, which I suspect the CV joint is starting to go. Not making noise other than a slight clunk when turning left under acceleration, classic sign. Plus when master cylinder was leaking it leaking through the boot. Daughter is taking back to mechanic. It could be a brake issue, possibly with caliper on that side as it seems as if the caliper may be moving as when you just come to a complete stop you feel some weird grabbing/moaning sensation.
05 Saturn Relay 97K
There are no new unread posts for this topic. bucking and coughing
wilden
Mon Jun 14, 2010 1:36 pm
There are no new unread posts for this topic. bucking Buick
mrvids
31
2587
Wed Oct 19, 2011 8:48 am
willwren View the latest post
There are no new unread posts for this topic. `A Bucking Bronc of a Bonneville
1964 Bonneville Ragtop
Sat Jun 04, 2016 10:19 pm
1964 Bonneville Ragtop View the latest post
There are no new unread posts for this topic. Heavy sputtering, popping, bucking.... HELP!!!!!
Bonneville92V688
Thu Jul 31, 2008 3:32 pm
lash View the latest post
There are no new unread posts for this topic. engine hesitation and bucking cont......
Mikeblo22
Sat Apr 30, 2011 5:37 pm
Mikeblo22 View the latest post
Users browsing this forum: 614justin, Exabot [Bot] and 5 guests
