It is currently Wed May 22, 2013 7:13 pm
PostPosted: Sun Oct 26, 2008 6:37 pm
Year and Trim: 2000 SSEi, Black 98000 mi 2/10
Pirelli P-Zero Nero
On my 2000 SSEi with 86,000 miles, I have recently been monitoring coolant leaking at the base of the bypass elbow only when the engine is cold. I know of the problems with the UIM and LIM but that does not appear to be the issue. No signs of coolant in the crankcase, just a small leak at the elbow. Can the elbow be replaced without dismantling all sorts of things?
Thanks,
Bob N
Bob N
PostPosted: Sun Oct 26, 2008 9:42 pm
The elbows can be replaced by removing the tensioner.
Black 2000 SSEi, HIR Headlights, Angel Eyes fogs, 3rd brake light overlay, hi-flo cat, drilled 180 degree thermostat, HS 1.9 rockers, LSx yellow springs, Intense FWI, PCM, shift kit, push rods, and 3.4 Pulley.
PostPosted: Mon Oct 27, 2008 9:50 am
Pirelli P-Zero Nero
Thanks Archon, any tips on removing the old elbow?
Bob N
PostPosted: Mon Oct 27, 2008 10:24 am
Banned
Year and Trim: 97 Ei
Remove alternator from the tensioner bracket assembly, then there should be two bolts, holding the assembly on. One to the left of the tensioner and one left of the coolant outlet passage.
From there work both elbow's (top and bottom) free and then replace both elbows. Dorman coolant elbow package 47065 contains both.
97 Ei
97 GS
98 GS
PostPosted: Mon Oct 27, 2008 10:39 am
Frankly, if you haven't changed the intake gaskets yet, that would be the way to go. If you're leaking from the elbow, it's quite possible the LIM gasket is in similar shape as they're made from similar material.
Drain the cooling system, remove the alternator, and then there are 3 bolts holding the tensioner in. Wiggling the tensioner a bit, try to pull it straight back, perhaps prying slightly against the elbow. Remember there is another plastic elbow on the lower left of the tensioner that goes to the water pump, so watch that one too. If they do break, they can usually be pried out with a screwdriver, but be careful not to score the aluminum, or you'll have another leak. Before replacing the elbows, clean out all the crud that will have built up or you again will have a leak.
PostPosted: Mon Oct 27, 2008 1:06 pm
Pirelli P-Zero Nero
Archon and BillBoost37,
I made a mistake on the part name, it's the HEATER WATER INLET PIPE. It looks like it would be relatively easy to replace, any advice.
Thanks,
Bob N
PostPosted: Mon Oct 27, 2008 1:23 pm
Banned
Ok..If I'm right on the name you gave us, it's one of the pipes under the hose remants in the picture. Those are pretty straight forward. Remove the 8mm bolt that holds it down and wiggle it out. Match up the O-ring as best as you can, clean the tensioner where the ring will go and then use oil/grease/vasoline to lube up the new ring and in it goes. Bolt back down. Refill with coolant.
I have found most of the O-rings on the car are compatible with the elbow o-rings or a kit of them I picked up at Harbor Freight.
97 Ei
97 GS
98 GS
PostPosted: Mon Oct 27, 2008 3:36 pm
Pirelli P-Zero Nero
Thanks for the info, if I could figure out how to add a photo, I would show it to you. In any case, you've covered the problem and even I should be able to fix it.
Thanks again,
Bob N
Bob N
There are no new unread posts for this topic. Coolant elbow leak
jastek1
Fri Jul 11, 2008 10:35 pm
jastek1 View the latest post
There are no new unread posts for this topic. Coolant is gone...254 degrees, cracked coolant elbow!
Ludichris
23
495
Thu Oct 25, 2012 2:04 pm
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. coolant elbow
jdq
Wed Sep 03, 2008 11:59 am
jdq View the latest post
There are no new unread posts for this topic. Coolant elbow question
Bichselmnop
Sat Nov 29, 2008 1:32 pm
This topic is locked, you cannot edit posts or make further replies. Coolant Elbow (Still) Leaking
yonkerse
15
1447
Fri Oct 12, 2012 7:28 pm
Users browsing this forum: MrT and 7 guests
