It is currently Thu Apr 19, 2018 1:22 pm
PostPosted: Sun Mar 18, 2012 2:43 pm
Online
Hello everyone. Does anyone know the brake line routing from the ABS Module that is right beside the master cylinder on a 2000 Buick Regal LS? What connection goes to what wheel? I am helping a friend with a brake line leak and this would really help in finding the correct line. There is almost no room to see the lines as they go down from the ABS module to the sub-frame. To make matters worse, the fuel lines are also routed down the same little space and makes it hard to see. Any help would be appreciated.......Thanks
PostPosted: Tue Mar 20, 2012 8:49 am
Online
Ok, I got it figured out. i couldn't tell what line from the abs mod goes to what wheel under the car by the sub-frame. I was alone so I got some straws and cut a piece off and slit it and slipped it over and down the brake line. When I get under the car I can see the straw and trace the rout of the line.....Ha Ha
The reservoir is on top of master cylinder. There are two lines going into the side of the abs module. There are four lines on the top of abs module.
Facing the rear of the car (standing in front of car)
From left to right
Rear right - Front left - Front right - Rear left
So rears are on the outside and fronts on the inside.
I think its a good idea to trace them all just to be sure because you never know what the last guy did.
Later all..........
There are no new unread posts for this topic. 2000 brake line help
cruizrisner
12
2083
Thu Jul 17, 2014 7:23 pm
carl View the latest post
There are no new unread posts for this topic. 2000 Chevy Impala LS 3800 Vacuum Hose Routing
dandyd
Fri Aug 22, 2014 2:17 pm
dandyd View the latest post
There are no new unread posts for this topic. Fuel/brake line corrosion
Mark Fahey
Mon Feb 06, 2012 1:08 am
leatherneck View the latest post
There are no new unread posts for this topic. seafoam through vacuum line 2000 SSEI
LAIDBACKLUKE
Sat Apr 16, 2011 11:29 pm
There are no new unread posts for this topic. 2000 SE EGR outlet line vacuum leak
Merrillspontiac
Wed Apr 12, 2017 2:36 pm
96 SSEi View the latest post
