It is currently Fri Jan 19, 2018 9:26 pm
PostPosted: Sat Aug 13, 2011 5:03 pm
Year and Trim: 2001 SSei
You do your research...figure out what part you need by following tech manuals and wiring diagrams......go to the local GM dealer and he tries to convince you to buy the WRONG part.....
I went looking for an Instrument Panel integration Module (IPM) and they said it was the same part as a Dash Integration Module (DIM)... :banghead: :banghead: :banghead:
I guess I'll have to pull the old one to get a part number for them..... :dontknow:
Unless someone knows the part number and would be kind enough to post it???
Oh...yeah.....01 SSEi
Thanks
PostPosted: Sat Aug 13, 2011 5:55 pm
The IPM is either 09390272 or 25733977... has a pink connector.
The DIM has a white/gray connector.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Sun Aug 14, 2011 6:51 pm
Ahh...that's good info.....are these the same on all Bonnevilles or just for the ones with the autotemp setup?
PostPosted: Sun Aug 14, 2011 10:43 pm
Not sure... but I'd assume they are all the same.
-Andrew-
