It is currently Thu Apr 19, 2018 1:23 pm
 Post subject: Front Transmission Mount
PostPosted: Mon May 09, 2011 7:44 pm
Year and Trim: 2003 SSEI(drilled 180*t-stat/Hockey puck)
(2003 SSEI) My front mount breaks at least once a year. I had the same problem on my previos 96SE. I had disscussed on the previous Bonneville forums about a high performance mount, Prothane or other companies but no one seems to care about us Bonne owners. I had heard of some guys using Hockey pucks and making there own. Has anybody tried this method for the 2003 model? My mount is broke again and I'd like to make this the last time I replace it. I came up with a design using a lenth of all-thread, some flat washers and nuts, and was going to use some eurothane suspension components. I never called Prothane or Energy Suspension to find an applicaple bushing to use. Looks good on paper but I never carried it out. Now I need another mount.
Any ideas?
I searched the forum and didn't get any hits on this subject.
PostPosted: Mon May 09, 2011 7:47 pm
The first item under transmission:
http://pontiacbonnevilleclub.com/forum/viewtopic.php?f=18&t=25362
PostPosted: Mon May 09, 2011 8:08 pm
Thanks for the link. A little problem I have with the hockey pucks, I can't run out to my local store in SOUTH LOUISIANA and pick up a few. Can you make one for me and ship it to me?? Just tell me how much $ to send you.
Andrew
PostPosted: Mon May 09, 2011 9:21 pm
Year and Trim: 2000 SSEi, 3.4", FWI, Saner HD sway bars,137K
They can be had on eBay for cheap.
PostPosted: Tue May 10, 2011 10:04 am
Big5 sporting goods carries them. You probably have one nearby.
PostPosted: Sat May 28, 2011 6:48 pm
I fabricated the mount using 3 hockey pucks, some washers, end link bushings and drilled everything for a 1/2" x 8" bolt. There is more vibration than I like. The end link bushings I used were cheap off the rack stuff and they don't last. My next try will be to remove the washers near the puck and put in a puck that I shaved off 3/8". Also I picked up a MOOG end link kit and drilled it for 1/2" and will put one under the rad support and one over the trans bracket.
If that doesn't please me I will try a completly different design using a clam shell motor mount from a chevy V8 and some creative iron work.
Has anyone tried that?
PostPosted: Sat May 28, 2011 8:33 pm
Year and Trim: 2002 pontiac bonneville ssei
If you're breaking it or wearing it out that much then you need to look at your other three mounts. They all kind of work together. I bet they're shot. If you replaced them you'd probably have to change the front a lot less often.
2002 Bonneville SSEI 170K
"Three men walking always has one teacher."
PostPosted: Thu Jun 02, 2011 8:08 pm
Year and Trim: 2003 Pontiac Bonneville SLE
Any ideas?
believe me im in the same boat and am about to make a hockey puck mount but am inda concerned over vibration.
2003 Pontiac Bonneville SLE - Sylvania Silverstar Fog lights, 5000k HID conversion low beams, Disabled DRL, cranking headlight delay kit, GXP style exhaust tips, solid front mount. Approx. 86k miles and still kickin strong!
PostPosted: Thu Jun 02, 2011 9:18 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Push an endlink bushing between the frame and the nut on the bottom and between a washer and the bracket on the top. lessens it a lot but yes it will vibrate some because its a solid mount.
I like it cause you can "feel" the car more.
There are no new unread posts for this topic. Front transmission mount
imidazol97
Sun Apr 10, 2011 2:06 pm
There are no new unread posts for this topic. Transmission Mount or Engine Mount?
00ssei
22
3186
Mon Jul 06, 2009 1:21 pm
00ssei View the latest post
J-ROD
17
4713
Tue Aug 31, 2010 5:17 pm
J-ROD View the latest post
There are no new unread posts for this topic. Transmission Mount Options
Schweet97Z
Fri Sep 17, 2010 11:31 am
J Wikoff View the latest post
There are no new unread posts for this topic. Rear Transmission mount
Z-type
Wed Aug 24, 2011 10:34 pm
Z-type View the latest post
