It is currently Tue Jun 19, 2018 8:10 am
 Post subject: oil sending unit
PostPosted: Wed Mar 17, 2010 6:17 pm
Year and Trim: 2000 SSEi Dark Blue Matallic
3.4 pulley
I know it's been covered before but I don't know where to find the answer.
My oil sending unit is pegged at 120. From what I have seen here
that means the unit is bad. Is one brand any better then the other?
And it sounds as if it a pretty simple fix.
 Post subject: Re: oil sending unit
PostPosted: Wed Mar 17, 2010 8:24 pm
Year and Trim: 2001 SE L36
Super simple fix and I really dont think brand will make much of a difference on this part. The sensor is above where the oil filter connects. A decent size crescent wrench should make short work of it.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
PostPosted: Thu Mar 18, 2010 12:41 am
AC Delco is recommended, people have had bad luck with other brands
PostPosted: Thu Mar 18, 2010 5:37 pm
3.4 pulley
Thanks for the help. I knew I would hear from someone with this information.
PostPosted: Sat Mar 27, 2010 4:18 pm
3.4 pulley
Will very much oil leak as I am putting in the new sending unit? And by the way ,I can get a AC Delco for $60.00
at Advance Auto parts. They have another brand for 40. I think I will go with the Delco. I might do the job tomorrow
so if somebody could get back to me tonight I appreciate.
PostPosted: Sat Mar 27, 2010 4:56 pm
It will drip out, but not too bad. Wear some safety glasses and don't wear clothes you don't want oil on. Other than that it just takes a bit to get it out, as it's in an ackward place.
PostPosted: Mon Mar 29, 2010 1:09 pm
Year and Trim: 2003 SSEi
Tech Info article has been posted. It's under TechInfo\Mechanical\Engine\Oil Pressure Sensor...
Or use this link:
http://www.pontiacbonnevilleclub.com/fo ... 47#p186347
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
There are no new unread posts for this topic. fuel level sending unit
bonneville dan-o
Thu Aug 20, 2009 4:06 pm
There are no new unread posts for this topic. removing fuel sending unit
matta46
Fri Jun 24, 2011 4:13 pm
There are no new unread posts for this topic. Car won't start after installing new fuel sending unit
Mckinney
26
656
Wed Dec 21, 2016 1:00 am
96 SSEi View the latest post
There are no new unread posts for this topic. Oil Pressure Sending Switch
mshipon
Mon Jan 03, 2011 10:02 pm
There are no new unread posts for this topic. EBay fuel pump and sending init
kennyz
Sat Jul 25, 2015 5:58 am
MikeKerr View the latest post
