It is currently Fri Jan 19, 2018 9:12 pm
Post new topic Reply to topic  [ 8 posts ]
 Post subject: Fuel Gauge Problems
PostPosted: Thu Dec 30, 2010 1:01 am
Year and Trim: 2000 Pontiac Bonneville SE
2009 Ford Escape
So I made sure to do a search for this first to see if anyone else was having this problem but I really didnt see anything exactly like mine
My fuel gauge has been acting sporadically lately.
I fill up my tank, and the first half of the tank every thing is fine, but then its as if I am no longer using gas....(I wish)
but then right about 250-275 miles, so I am guessing that there is maybe a quarter tank left it shoots up to full and stays there.
I have tried parking on inclines and declines, I tried sitting on a flat surface idling, banging on the fuel tank see I cant jar something loose. but all to no avail.
I have no real problems with it. I just fill up every 350 miles or so, but the wife wants me to see how difficult/expensive a problem it is to fix.
So please help, if you need more info I will be more than willing to oblige. Again I have no problems with this, but at the end of the day one must remember
happy wife= happy life. :btruestory:
Fault lies with the man low enough to lay blame.
 Post subject: Re: Fuel Gauge Problems
PostPosted: Thu Dec 30, 2010 1:07 am
Year and Trim: 2000 Bonneville SLE
I am the wife driving the car!! And mine does the same thing. I have opened up the cap to see if that helps and it does seem to. It happened again tonite. I knew I had less than a 1/4 tank but it read full. Then suddenly it told me to check fuel gauges!!
Share if you find anything out.
Sheila-Marie
2000 Bonneville SLE
Sheila-Marie
[IMG]http://i102.photobucket.com/albums/m94/GEMS1965/Bonnevilleinsnow2011.jpg[/IMG]
PostPosted: Thu Dec 30, 2010 1:11 am
This is a very common problem. Fuel lever sensor is bad. It is located in the trunk under the fuel pump. You can buy one for a Yukon, and save yourself money. They use the same part.
PostPosted: Thu Dec 30, 2010 1:13 am
2009 Ford Escape
I kinda figured that was what it was, but everyone I have spoke to says I have to replace the pump as well, that they are not two separate units. :dontknow:
Well thanks, I will look into this and see what I find.
Thanks
PostPosted: Thu Dec 30, 2010 1:16 am
This may help you out.
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=9&t=3463
PostPosted: Fri Dec 31, 2010 9:55 am
2009 Ford Escape
bloody brilliant!!!!
Its so good its making me talk like a britt, and I hate the britts, lol!!!
Actually I really dont.
but thanks a ton.
:bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo: :bwoohoo:
PostPosted: Fri Dec 31, 2010 10:25 am
2009 Ford Escape
Ok, so none of the dealers in the area have that part in stock. Anyone know what this part is called so I could check autozone?
PostPosted: Fri Dec 31, 2010 10:51 am
It looks like Dorman (P/N 911-007) is making a kit now.
There are no new unread posts for this topic. Fuel gauge erratic : check gages light still comes low fuel
MrPOPE
Fri May 16, 2014 10:02 am
MrPOPE View the latest post
There are no new unread posts for this topic. Fuel Gauge issues (not fuel sender)
Ghh0st
Sun Jun 14, 2015 10:31 am
bobtaz13
Mon Dec 12, 2011 8:37 pm
bobtaz13 View the latest post
wwade2
Tue Feb 24, 2015 11:59 am
ddalder View the latest post
There are no new unread posts for this topic. confused fuel gauge
Night Crawler
Mon Mar 16, 2009 10:30 pm
Night Crawler View the latest post
Users browsing this forum: No registered users and 9 guests
