It is currently Thu Apr 19, 2018 7:44 am
 Post subject: Throwing code P0420
PostPosted: Wed Jul 07, 2010 9:54 am
Year and Trim: 93 SE
04 GXP
got the SES light the other day and got it scanned came back P0420 i did a search here and didnt find anything northstar powered any ideas what it may be like the cat or is it the rear sensor
 Post subject: Re: Throwing code P0420
PostPosted: Wed Jul 07, 2010 10:25 am
Its most likely a rear sensor. Is the car running normal, good acceleration.....?
A P0420 diagnostic trouble code is a "generic" fault code that is set when the Onboard Diagnostic II (OBD II) system sees a drop in converter efficiency. The OBD II system monitors catalyst efficiency by comparing the switching activity of the upstream and downstream oxygen sensors in the exhaust. The upstream O2 sensor in the exhaust manifold reflects the condition of the exhaust gases as they exit the engine. The downstream O2 sensor in or behind the catalytic converter reflects the condition of the exhaust after it passes through he converter.
The catalytic converter is like an after-burner. It oxidizes (burns) any residual fuel vapors (unburned hydrocarbons or HC) in the exhaust. It also burns any carbon monoxide (CO) in the exhaust. The exhaust must meet federal emission standards, and if a problem exists that causes emissions to exceed the federal limits by 150%, the OBD II system is supposed to catch the fault, set a code and turn on the Check Engine light.
The OBD II system can't actually measure the concentration of HC or CO in the exhaust, so it compares the upstream and downstream O2 sensor readings to estimate how well the catalyst is actually doing its job of removing pollutants from the exhaust.
The upstream O2 sensor will typically show a lot of switching activity because the engine computer is constantly adjusting the fuel mixture between rich (more fuel) and lean (less fuel). When the engine is first started, the catalyst is cold and doesn't do much. During this time, the switching activity of the upstream and downstream O2 sensors are essentially the same because nothing is happening inside the converter.
When the converter reaches about 600 degrees F, it is hot enough to start reacting with the gases in the exhaust. This is called the catalyst's "light off" temperature. The converter now starts to clean the exhaust and remove the pollutants. This causes a sudden drop in the switching activity of the downstream O2 sensor, and the sensor's output voltage levels off to an average reading of around 0.45 volts. This tells the OBD II system that the catalyst is doing its job and that everything is fine.
The OBD II catalyst monitor only runs under certain operating conditions, which typically require a combination of city and highway driving on the same drive cycle. If the catalyst monitor has run and no faults are found, the converter should be functioning properly and the vehicle should be in emissions compliance. But if the catalyst monitor runs and finds too much switching activity in the downstream O2 sensor after the converter is hot and the vehicle is being driven, it may set a P0420 code and turn on the Check Engine light.
J Wikoff wrote:
It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
PostPosted: Fri Jul 23, 2010 11:26 am
Year and Trim: 2006 Cadillac STS-V, 2004 Pontiac GTO
This thread, post #10 by Me, details what the code is, and how to troubleshoot it.
viewtopic.php?f=8&t=12335&p=131397&hilit=P0420#p131397
There are no new unread posts for this topic. GXP is throwing a P1570?
Fri Jun 11, 2010 12:42 am
There are no new unread posts for this topic. P0420
dpnewfie
Thu May 10, 2012 11:49 am
There are no new unread posts for this topic. SES code, what does it mean?
epic_pwn_95
Mon Apr 25, 2011 7:05 pm
epic_pwn_95 View the latest post
There are no new unread posts for this topic. I need help! P0502 code
05Bonnie&Clyde
19
2714
Fri Mar 09, 2012 6:06 pm
There are no new unread posts for this topic. P0422 Code Help
Gagger14
Wed Aug 15, 2012 12:26 pm
