It is currently Tue Jun 19, 2018 8:01 am
PostPosted: Sun Jul 13, 2008 5:50 pm
Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
how do you replace the rear speakers for a 2002 bonni ? I crawled inside my trunk and I didn't see any screws ? i blew a speaker and I'm planning on replacing them both ?
PostPosted: Sun Jul 13, 2008 6:06 pm
You have to go from the top, from inside the car. You can either pull the speaker grills off, or remove the whole back cover.
-Joshua-
PostPosted: Mon Jul 14, 2008 10:03 pm
ALL STOCK (FOR noW)
okay... um how which is easy or they both about the same way ?
PostPosted: Tue Jul 15, 2008 6:54 am
I don't know that the grills come off the dash very nicely. Its best to remove the back dash to get to it.
Use a large flat blade screwdriver inserted from the top down behind the seat back. There are 4 clips that need to be pushed down and then the seat back will pop out.
The rear dash comes out after you remove the C-pillars and the 2 push in connectors.
Quote:
Seat Back Replacement - Rear
Removal Procedure
Remove the upper trunk trim.
Remove the fasteners and the cable clips from the trunk pass-through release cable, If equipped.
Remove the rear seat cushion. Refer to Seat Cushion Replacement - Rear .
Remove the center seat belt and outer shoulder belt buckle anchor fasteners.
Lift the center shoulder belt off of the seat back and store on the rear shelf panel.
Using a straight-bladed screwdriver, insert the screwdriver between the top of the seat back and rear of the shelf panel.
Push down on the screwdriver in order to release the rear seat back retainers.
Release the 4 retainers and pull the seat back away from the cross car beam.
Position the rear shoulder belts in order to clear the rear seat back.
Pull the seat away from shelf panel far enough to pull the pass-through release cable through the opening.
Remove the rear seat back.
Installation Procedure
Install the rear seat back into the car.
Feed the pass-through release cable through the opening behind seat back, If equipped.
Position the rear shoulder belts over the seat back.
Align the slots in the seat back with the retainer clips on the cross car beam.
Push the seat back firmly in order to engage the center clips and then the outer clips.
Position the center shoulder belt over the seat back.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Important
Ensure that the fastener threads and fastener holes are free of any sealer patch material.
Install the center seat belt and outer shoulder belt buckle fasteners. Tighten
Tighten the fasteners to 41 N·m (32 lb ft).
Install the rear seat cushion. Refer to Seat Cushion Replacement - Rear .
Install the pass-through release cable fasteners and cable clips.
Install the upper trunk trim.
Quote:
Trim Panel Replacement - Rear Window Shelf
Removal Procedure
Remove the rear seat. Refer to Seat Back Replacement - Rear in Seats.
Remove the seat belts escutcheons from the rear shelf.
Remove the push-in fasteners at the front of the rear shelf trim panel.
Feed the center seat belt through the opening in the rear shelf trim panel.
Slide the outer seat belts through the slots in the rear shelf trim panel.
Remove the rear shelf trim panel.
Install the rear shelf trim panel to the vehicle.
Route the center seat belt through the opening in the rear shelf trim panel.
Snap the seat belt escutcheons into the rear shelf trim panel.
Install the push-in fasteners at the front of the rear shelf trim panel.
Install the rear seat. Refer to Seat Back Replacement - Rear in Seats.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Wed Jul 16, 2008 5:28 pm
ALL STOCK (FOR noW)
um.. o okay good write-up next question how long does something like this take ?
PostPosted: Wed Jul 16, 2008 10:44 pm
Probably about an hour for doing this for the first time. I just did it in 10 minutes today, but its like my 8th time.
-Andrew-
PostPosted: Fri Aug 01, 2008 9:08 am
good info and pics there.
i will add, i was able to replace mine without pulled the rear seat out. You can gain access to the push retainers for the rear deck by simply pulling on the rear seat tops and then pulling the retainers out. Once these are out, you will need to pull the rear side pillars...then i was able to lift the rear deck out and gain access to rear 6X9s.
"You cannot legislate the poor into freedom by legislating the wealthy out of freedom.
What one person receives without working for, another person must work for without receiving.
The government cannot give to anybody anything that the government does not first take from somebody else.
When half of the people get the idea that they do not have to work because the other half is going to take care of them,
and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for,
that my dear friend, is about the end of any nation.
You cannot multiply wealth by dividing it."
~~~~~ Dr. Adrian Rogers, 1931 - 2005 ~~~~~
PostPosted: Fri Aug 01, 2008 12:42 pm
Very good idea.. I would have never thought of that. Plus, you get to keep the padding to sit on while you work!
-Andrew-
PostPosted: Tue Oct 21, 2008 11:19 pm
Year and Trim: 1999 Pontiac Bonneville SLE
Are these instructions at all similar to pre-00 Bonnevilles? I'm interested in doing the same exchange on my 99. Where did you find these instructions?
Thanks.
PostPosted: Wed Oct 22, 2008 2:05 am
Year and Trim: 2007 Grand Prix GT
The 99's are easy to do, dive in the trunk and there you go. Although I can get to mine by removing the speaker grills.
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
There are no new unread posts for this topic. Replacing factory speakers
PLAGUE PHANTOM
Tue Apr 12, 2011 9:55 am
willwren View the latest post
There are no new unread posts for this topic. Replacing monsoon 6x9 speakers
haro1225
Fri Jan 11, 2013 12:37 am
haro1225 View the latest post
There are no new unread posts for this topic. replacing front door speakers.
razmatazz
Tue Aug 30, 2011 10:21 pm
Bugsi View the latest post
There are no new unread posts for this topic. rear speakers
lynn37
Sat Nov 28, 2009 9:37 pm
1fatcat View the latest post
lynn37
Fri Jul 30, 2010 10:14 pm
97SEBonnevilleMan View the latest post
cron
