It is currently Fri Jan 19, 2018 9:17 pm
PostPosted: Sat Sep 19, 2009 2:07 pm
Year and Trim: N/A
My car has the stock GM CD player/Radio/Tape deck and I'm just trying to figure out how to remove it and replace it. I see that is has a piece of plastic over it along with the air conditioner controls. Is there a safe way to remove the plastic so I can get to the stereo.
In addition, I'm debating whether or not to replace it with an aftermarket one because if I were to buy an aftermarket stereo, would the play, seek, and volume buttons on my steering wheel still work? Would I have to get a wire conversion kit of some kind with an aftermarket stereo? Plus the ones at my local store are smaller than the hole where the OEM stereo is. What kind of plastic piece would I have to get to fit one of those thinner aftermarket stereos inside?
PostPosted: Sat Sep 19, 2009 3:22 pm
Year and Trim: 2000 ssei
ok to answer your questions, the plastic trim just pops off there are clips that hold it in different locations.
here is a pretty good writeup for the install viewtopic.php?f=13&t=7319&hilit=radio
you will need an adapter if you want to keep your door chimes i used the PAC c2r-gm32r
you will also need another adapter to keep your steering wheel controls I used the PAC swi-PS which works with pioneer and sony units
also with the bose you will have to run the remote wire to the amp behind the back seat and splice it with a wire to make the amp turn on
2000 ssei white debadged, autozone solid front mount, NGK tr55 plugs, Napa Beldin wires, MSD Coils, drilled slotted rotors, monroe max air rear shocks, 18" KMC Hot wheels redline w/ 235/50/18 bfg G-force tires, pioneer DEH-P580mp deck, Infinity Ref 6.5s and 5.25s, Kappa 6x9's on crossfire amp, kappa 12 on kenwood amp, and cleared headlights.
Gumball wrote:
my pockets dont sag and are still kinda tight.
PostPosted: Tue Sep 29, 2009 10:09 pm
Year and Trim: N/A
Oh I didn't want to install any amps or speakers in the back. I'm perfectly happy with all the OEM speakers but they are Bose. All I'm interested in replacing is the unit because the LCD on the unit is burned out and I've concluded buying a brand-new aftermarket one would be cheaper than trying to find the OEM unit off eBay.
PostPosted: Tue Sep 29, 2009 10:13 pm
viewtopic.php?f=18&t=7449&hilit=i+will+fix
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Wed Sep 30, 2009 6:40 am
i was referring to the stock bose amp that sits on the back of the seat on the drivers side you have to run a remote wire to if you replace the factory unit
PostPosted: Thu Oct 01, 2009 9:10 pm
Year and Trim: N/A
I only have 1 burned out bulb behind the LCD display. But do I have to order a replacement bulb off that corvetteradios website??? I don't want to pay $23 for 3 bulbs of which only 1 if possible. Could I get the bulbs for the display from Radio Shack?
PostPosted: Mon Oct 05, 2009 10:16 pm
I'll sell you 1 bulb if you want. I bought a bunch from Corvetteradios a while back.
PM me.
-Andrew-
There are no new unread posts for this topic. 2000 SSEi add sub to stock stereo?
Blk2000SSEI
Mon Nov 11, 2013 12:21 pm
There are no new unread posts for this topic. Stereo replacement (2000 SSEi)
Daveburt
Sat Feb 21, 2015 6:49 pm
There are no new unread posts for this topic. 2000 bonneville aftermarket stereo
Jaymeson123
Fri Feb 03, 2017 12:58 am
redfury View the latest post
There are no new unread posts for this topic. amplifying the factory stereo 2000 ssei
shredthebonnie
Mon Nov 16, 2009 12:05 am
99bonnieSE View the latest post
There are no new unread posts for this topic. Stereo lights out - should I fix or replace
jargarner
Tue Sep 23, 2014 5:04 pm
