Making L26 aluminum UIM work on an L36
agrazela
Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired
Post by agrazela »
So you want to put an L26 aluminum UIM on your L36?
(This is a work-in-progress for another member here, and here's where it is now.)
L26 aluminum UIM (from a 2005 LaCrosse):
The runner insert, PCV valve, MAP sensor (and the gasket AFAIK) are just like on the L36 plastic UIM.
L26 LIM is identical in every way to the 99+ L36 LIM with the 5/8" diameter EGR stovepipe...
EXCEPT that the L26 EGR pipe is about 1/8" shorter than the L36:
So, to avoid the EGR stovepipe protruding into the inlet airstream, you need to either shorten your L36 stovepipe OR get an L26 stovepipe. Otherwise, the L26 UIM will bolt right up to your current LIM, using the same bolts you have now.
Now for the modifications...
EVAP hole:
Whereas the L36 has it's EVAP solenoid routed to the TB through a vacuum line, L26 UIM has the EVAP solenoid bolted right to the UIM, with it's opening just to the right of the TB inlet (if looking into the inlet):
That hole is just the right size to tap 1/4" NPT, then plug with a pipe plug:
Alternately, that hole could be filled with epoxy.
PCV inlet:
On the L36 (or L67) TB, the PCV air inlet is in the throat of the TB (after the MAF, so the air is pre-metered):
On the L26, the PCV air inlet is the vertical "nipple" on the top:
Which is connected by some vac line into the air intake bellows on the L26, after its' MAF setup.
There is no easy way to adapt the PCV inlet hole in the L36 or L67 TB to this L26 UIM, so we have to make our own PCV air inlet.
Drill a 3/8" hole through the side of the UIM, right about where this red circle is:
Make sure that crosses through the vertical PCV inlet "airshaft", and right into the inner "throat" of the inlet:
This hole in the inner throat is the new after-MAF PCV air inlet.
I enlarged the outer part of the hole to 7/16", tapped to 1/4" NPT, and plugged with a pipe plug:
I suppose that outer hole could be drilled/plugged for a smaller plug, or even epoxied (just don't block the inner air passages).
Then cap that nipple up top with a 3/8" vacuum cap:
That nipple could be pulled out / drilled and tapped / plugged, but the vac cap was much easier. Alternatively, I suppose that nipple could be used as a vacuum source (e.g., for the vac modulator on a 4T60E, if you are 96/97 and earlier).
This should produce a clean, fully-functioning PCV system.
Next up will be adapting an L67 TB to the L26 UIM, stay tuned :)
Bone Stock
Retired
firebuick
Year and Trim: buick allure 2007
NEBF07 ONBF07 ONBF08
Re: Making L26 aluminum UIM work on an L36
Post by firebuick »
andrews is the insert different from a stock L36
buick regal ls 2002 L36 Buick regal 1983 357 sbc ,2003 Buick park avenue ultra
modkn4750,CAI,er rockers,powerlog,2.5 downpipe,high flow cat,dynomax muffler,hv3,ported LIM,autolite 104,waterpump u/d pulley,180 stat,aeroforce scan gauge,etx mag 17x7.5,245-45-17 flaken ze 912,
pb 14.97@92.77mph 2007 pb 2008 95.45 mph
don
agrazela
98 Lesabre, Retired
Post by agrazela »
firebuick wrote:andrews is the insert different from a stock L36
I do not currently have an L36 insert in hand to compare side-by-side; however, it sure looks the same to me, and I have heard others say it is the same. When it comes time to test this thing, I will make sure they get more closely compared.
Also, will an HV3 insert fit in this L26 UIM? I do not know if the inner countours of the "body" of the L26 UIM are exactly perfectly 100% identical. I think the person for whom I am making this is considering an HV3, so maybe we'll find out :)
Bone Stock
Retired
agrazela
98 Lesabre, Retired
Post by agrazela »
Adapting a TB:
Because the L26 UIM has a round inlet, it would be best to use an L67 TB (with it's round outlet):
Since L36 MAF tables are not the same as L67 MAF tables (even between those using the same MAF sensor), you will need a tuner (or PCM) to reprogram the MAF table for an L67 TB. Use a stock, unmodified L67 TB of known year and any competent tuner (or PCM vendor) will already know the proper MAF table to put in. Use a vendor-supplied modded TB and they should be able to provide a starter MAF table. Use a home-ported TB and you better have a tuner!
ZZP makes a machined aluminum adapter designed to adapt the L67 TB to an L26 UIM or GenV s/c. Here is a used one for this project:
Four of the screws bolt the plate to the L26 (in the recessed holes), and the other three hold the TB to the plate.
The aluminum adapter is kinda pricey new ($100), and I think the ZZP phenolic TB spacer could easily be adapted to this job:
ALTHOUGH you would have to block the TB coolant ports at either the LIM or the UIM to use it:
These phenolics are usually pretty cheap used. Of course, you machine your own from aluminum if you got the tools. Heck, if your TB coolant ports and EGR are blocked off, I bet you could make an adapter out of wood!
One thing nice about the ZZP aluminum adapter is that it will block off the TB coolant ports itself. OR, if you want TB coolant flow (as the patron for this project does), you can add them:
Now the TB coolant flow ports on the L26 UIM are not in exactly the same place as on the M90 casing:
So you can't just drill straight through. But if you locate the holes right, you can drill the back (side touching the L26 UIM) 7/16" bit, 1/2" deep:
And the front (side touching the TB) 3/8" bit, same depth:
They are offset, but they do meet in the middle and the coolant passages are good.
The inlet hole on this ZZP aluminum adapter is a perfect match for the machined part of the L26 UIM inlet:
However, the machined part has a mismatch to the cast part, leaving a turbulence-causing "lip" (similar to what you see in stock M90 casings):
Easily fixed with a dremel and a small teardrop carbide burr:
You could port that out more, but the rest of the throat is pretty danged smooth already so I didn't bother.
To seal all this, all you should need is a few rings of RTV on the L26 UIM inlet:
And a stock L67 TB gasket (or better yet a reuseable one like this):
OK, that should take care of function. Now there are issues of fitment.
The inlet "snout" on the L26 UIM is longer than that on an L36...especially when you figure in the adapter plate, too:
This will modify the location of the TB, pushing it toward the driver's side about 1" to 1.5"
The harness should have enough reach to hook up all the TB sensors no problem. But, this will very likely mess with the length of the vac lines attached to that "split fitting" on nipple on the side of the TB and that go to the EVAP solenoid (1/4" plastic line) and FPR (5/32" plastic line). The lines will probably have to be lengthened with a section of rubber vaccum fitting / hosing, replaced with some longer self-bent plastic line, or replaced with rubber vacuum hose and some sort of plastic fittings. Still deciding on the best way to rectify that. This will be pretty much universal for any L36, so whatever I come up with on the vac lines should translate for anyone.
This change in TB location could screw with other things, like:
-Throttle and cruise control cable bend radii
-Fitment / "bend radius" of the stock air intake bellows
These "other things" are not necessarily universal between different car models / "generations", so you're kind of on your own there!
Also, on the off chance that the outer dimensions of this UIM "casing" are not exactly the same as an L36 UIM's, there could be a fitment issue on the bigger, bulkier alternators of the pre-2000 H-body crowd...another thing to test-fit :wink:
It will probably be a couple weeks before this thing get installed for testing, so if anyone sees anything I've overlooked, let me know!
Bone Stock
Retired
TenGHz
Post by TenGHz »
Very interesting write up! I have an L36 with a stock UIM and it looks temptingly simple for me to do the swap! It looks easy enough that a moron like me could do it. :lol: Thanks for the info!
-Joshua-
agrazela
98 Lesabre, Retired
Post by agrazela »
Some clarification on the vacuum lines and fitment:
As mentioned, the L26 inlet plus adapter is longer than the L36:
By a good 2.5 inches. This is going to play heck with your stock air intake bellows:
And may be an issue if you have a hard tube intake ("ricepipe") already cut to fit your L36.
As to vac lines, I should have known better than to use the word "universal" :lol:
Here's what my 1998 looks like (my 2004 is about the same):
Line A goes to the FPR, line B goes to the EVAP solenoid. Both would need to be lengthened by that 2.5"
Here's a 1995 L36:
Line A goes to FPR and needs to be lengthened that 2.5"
Lines B and C go to the EVAP and the 4T60E vac modulator (I believe respectively, though I am not 100% sure :oops: ) The line going to EVAP will need to be shortened by 2.5", whereas if using a newer L67 TB on a 4T60E-equipped car, one of those TB nipples will be gone and perhaps that nipple on top of the L26 UIM can be adapted to work the modulator.
(Or vice-versa--use the L26 UIM nipple for the EVAP and run the split fitting on the TB to the modulator.)
One more note: I measured the EGR hole on the bottom of the L26 aluminum UIM at 0.753" ID, so the 3/4" OD EGR stovepipe from a pre-99 L36 should fit into it.
Bone Stock
Retired
firebuick
Post by firebuick »
i don't see any more power from the L26 upper so this swap is only for something more durable
maybe a bit whit the L67 TB do you think its worth it
don
agrazela
98 Lesabre, Retired
Post by agrazela »
firebuick wrote:i don't see any more power from the L26 upper so this swap is only for something more durable
I see these benefits:
1) Reliability: Greater durability than plastic (like you said); also possibly more reliable as a turbo UIM?
2) Performance: Rounded inlet probably better than "butterfly-shaped" L36 UIM inlet for going to an L67 (or N*) TB (also like you said)
3) Appearance: Can be polished or painted / powder coated
Bone Stock
Retired
TenGHz
Post by TenGHz »
Is this installed now? Any more hang-ups found?
I'm really interested in copying your work. :wink:
-Joshua-
Bob Dillon
Post by Bob Dillon »
agrazela wrote:Some clarification on the vacuum lines and fitment:
By a good 2.5 inches. This is going to play heck with your stock air intake bellows.
My first thought there would be to section the L26's longer tube by the 2 1/2" (or as much as possible) and then heliarc the pieces back together. That would solve a lot of problems with the TB and cruise control linkage.
