It is currently Tue Feb 09, 2010 2:30 am
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject:
PostPosted: Fri Nov 20, 2009 10:17 pm
Year and Trim: 1995 Pontiac Bonneville Sport Luxury Edition
Anyone who lowers a truck IMO, should have bought a car. (Or a station wagon :wink: )
| 3800 Series II | Intense FWI | FE2 Suspension | Updated Dorman UIM | Borg Warner Select Wires | AutoLite Iridium Xtreme Performance Plugs | Painted calipers/drums | 160amp High Output Alternator | 03' Bonneville 17" Chrome Wheels | LED lighting | Fire Extinguisher in trunk | Cadillac Auto-Dim Mirror | BlueTint Heated side mirrors | Pinstripes removed | Clear Corners | Dynomax Super Turbo muffler /w dual out | Optima Red Top | Alternator Sensor 14v mod | Tinted Windows | AL7 Seats | 00+ Leather Shifter | Angel Eye Driving Lights /w PIAA Intense White | PIAA Intense White High/Low Beams | GM Emblems | 05' SLE Door Emblems | Custom wire mesh grill | Imported custom Italian leather shift boot /w tan stitch | AMSOIL Fluids | Throttle Body coolant delete | "1SICKSLE" License plates |
YIM
 Post subject:
PostPosted: Sat Nov 21, 2009 12:41 am
Year and Trim: 2003 SSEi
2005 GXP
I like some lowered trucks, depending on the combination. Some people need a truck for hauling crap, but don't like how high it sits. I have no problem with a lowered truck. I want to lower my 67 C20, and put some nice wheels and tires on it.
2003 SSEi | My DD | Silver Steel Gray Metallic | 158,xxx miles | Intense FWI, 180* T-stat | Smoothflow Polished 3.6 MPS | Aeroforce Interceptor Scan Gauge| Custom Tuned PCM
Disabled DRL's | Cleared Front Headlights | VHT Nighshades Tinted Tails | EBC Ultimax Rotors & Red Stuff Brake Pads | Monroe Max Air Shocks | GXP Carbon Fiber Vents
Coming Soon on SSEi: PLog & DP | Tranny Cooler | 1.9 YT Rockers
2005 GXP| Dad's DD | Cranberry Red Metallic | 59,xxx miles | 9005 Headlight Conversion | Napa Premium Front Rotors and Ultra Premium Front Pads | Kumho Ecsta ASX 235/55R18
 Post subject:
PostPosted: Sun Nov 22, 2009 10:31 pm
Year and Trim: 1997 Buick LeSabre Limited
1996 Chevrolet S10 LS
Yeah, lowering isn't too bad I guess...it just gets a little old on the S10 forum. It's amazing how far the lengths some of those guys will go to and the finances they will strain just to make those things sit so low to the ground that they look retarded, lol.
Plus, when they start talking about doing it to rare vintage cars, it kind of makes me want to punch a kitten.
I know you guys are probably tired of my mind switching back and forth, lol, but I have found ANOTHER option...and this one is cheaper than either the s/c or V8 swap.
How about a performance camshaft? Cost is lower, I think I'd be able to keep my total costs below $1250 and that's with a pretty aggressive cam setup.
Check this out. This guy has a 266ahr cam (which is relatively mild) in his nearly stock Sonoma. All he has other than the cam is a performance exhaust.
http://videos.streetfire.net/video/S15- ... 149645.htm
Not too bad! I think he managed a 5-6 second 0-60 time, even with the loss of traction between the 1-2 shift.
I like this because of it's low cost. I can do this and some other things I really want, instead of just one thing. I'm still researching it though, I want to know how it will affect daily driveablility and what the expected power gains are.
-Dan
- LeSabre - The luxury yacht - 3.06 Gears, F41 Suspension, Gran Touring package, leather, fully loaded.
- S10 - The luxury truck - 4.3 Vortec V6, 68,000 miles, 3.42 gears, towing package, leather, wood, sound.
 Post subject:
PostPosted: Mon Nov 23, 2009 10:53 pm
Year and Trim: 1999 Custom
Ooh! I likey this camshaft idea the bestest!
With a cam and a tune, you'd get a very quick truck.
Lowering isn't too bad if you keep it mild so it doesn't look too out of the ordinary. Too low and it's a lot of issues. But yeah, a mild drop would go well with that truck. Say 1.5" all around. Then you'd still have ground clearance and better handling from the lower center of gravity.
1999 Buick LeSabre Custom - The Rolling Couch
Ported/polished lower intake manifold - gutted airbox - B&M SuperCooler 70268 - 180* thermostat - ScanGauge II - Intense PCM - DIY shift kit
 Post subject:
PostPosted: Mon Nov 23, 2009 10:58 pm
Yeah Dave, that's what I'm hoping for!
I've kind of got in my mind that with a decent cam it will drive sort of like the Hemi Ram I drive a lot at work. The engine in the Ram doesn't seem fit for a truck really. It doesn't have a whole lot of low end, but then the power comes on hard at around 2000 rpms...and it will really pull! It's fun to drive for that reason cause it will just fly around town even when you're not giving it a lot of throttle, although the revs are up there, and it sounds sexy as hell while doing it. My truck might not manage the get the sound, but if it could mimic the driving dynamics, that would be pretty cool. My truck is pretty flat above 2000 rpms unless it's floored.
-Dan
 Post subject:
PostPosted: Sat Dec 05, 2009 12:06 am
Update.
Those of you at SEBF may remember that the reclining handle for the passenger's seat was well...destroyed.
I actually recently found a company whose sole purpose is manufacturing aftermarket handles for the S10/Blazer family that are designed not to break. I guess it's a fairly common problem.
If you're wondering why the handle was in place in a previous picture, that handle was off my old seats and I just put it there to make the picture turn out all pretty-like.
Here's what was left of my reclining handle.
I pretty much thought I was screwed there. You could recline the seat with a flathead screwdriver, but that's a pretty socially awkward situation, to make your passenger step out with a screwdriver to recline their seat.
So here's the solution:
It's an almost-match. Color is perfect but it sticks out a little further than it would stock. Functionality wise, this is actually better, as you can get your whole hand around the handle.
Now for a bigger update.
All the ideas I was throwing around about performance items for this truck, are unlikely to happen, at least in the near future. I got to looking at my LeSabre and thought the money could be better justified being spent on it versus my low mile truck. So right now, things are getting moving on the LeSabre project. I'll make a thread about what I have planned and progress once things get serious.
-Dan
 Post subject:
PostPosted: Tue Dec 22, 2009 9:54 pm
Okay, so here's an update on this little project.
I took another step towards finishing the Chevrollac project with these HIDs.
For a long time, I've wanted to put HIDs in this truck, I've tried various ideas and none of them work. The conversion housings you usually find for sealed beam vehicles either suck or are prohibitively expensive, or both.
But then after a ton of researching, I found these. Autopal E Code H4 conversion housings.
E Code is a European standard for headlights...kinda like ours except theirs doesn't suck. DOT requires that headlights be able to cast some light upward to illuminate overhead signs. This is where your glare comes from with PNP HID kits. E Code lights mandate a sharp cutoff and even light distribution instead. Definitely the better choice.
Quality is great too. They feel just as hefty and well built as a stock sealed beam. No cracking from a tiny pebble with these. All metal and glass construction.
I coupled this with a high/low H4 HID kit from DDM tuning. Wow, I wish I could put HID high beams in my Buick...they're great!
But the best part is the cutoff. These are actual pics of mine from my truck.
It's not as good as a projector, but *dang*...show me a halogen housing with a better cutoff!
Those two spikes aiming up and off to the right are intentionally designed into the headlight lens...they are meant to illuminate roadside signs. And I do need to do a little more adjusting. Ideally there should be no gap in the middle, it should be one even bar of continuous light. But you get the idea.
I'm pretty pleased. As I said the light distribution is fantastic.
Low beams.
High beams.
As you can see there are no hotspots or unnecessarily scattered light.
I also chose 5000k for these. I like 5000k because it provides excellent light output and the color looks exactly (to me) like factory HID equipped cars.
Here is about what opposing traffic sees:
As opposed to what it looks like inside the cutoff:
HUGE improvement over sealed beams!
-Dan
 Post subject:
PostPosted: Wed Dec 23, 2009 1:02 am
Nice lights! I really like the H4 bulb in a properly designed housing.
 Post subject:
PostPosted: Wed Dec 23, 2009 2:59 am
Year and Trim: 06 Volkswagen GTI
4300k is OEM... It only appears blue because of the cutoff bending light.
Previously owned: 1993 Bonneville SE Purple Pearl (traded-in sadly) 1st evar!!111! rice pipe intake - flowmaster 80 (loud as piss) - upgraded suspension bits -
- tinted tails - big stereo - full red interior lighting - ZM modified TB - push button start - BFGoodrich Traction T/A - "best" evar 15.9 @ 84MPH @ Byron -
 Post subject:
PostPosted: Wed Dec 23, 2009 3:08 am
Yes I know. Maybe I wasn't clear with how I described it, but I meant it looks like factory HIDs to a bystander.
Although, factory reflector based HID systems are often fitted with replacement 5000k bulbs, from what I've read.
And thanks Dave. :wink:
-Dan
 Post subject:
PostPosted: Mon Feb 01, 2010 7:34 pm
I guess this is going to be the official topic of my truck from now on, lol. I prefer updating one thread rather than creating several.
Nothing much new. Still loving the HID + ECodes. I was able to aim them up a little higher, and now my low beam and high beam is even better. Really, it's like a narrow projector pattern. Can't complain, and it doesn't blind anyone.
I was unloading some stuff from the truck out to the shed in the side yard today and thought "hey that would make a pretty cool picture" but it ended up looking a lot cooler in person, lol! I blame the crappy camera. Now the live view doesn't work anymore and I have to use the viewfinder. Seriously getting a new camera soon.
Had a lot of material in the back...you can see the rear sagging a little...the towing package with the stiffer springs helps that a lot though. Bringing in stuff to rebuild the very back yard which you can sorta see. Neighbor built a dam on the creek and it ended up bursting, trashing everything immediately downstream. Most of it is cleaned up but I've got to fill in a few spots.
Not sure I ever got 'quality' pics of the interior, so here's my best attempt with a craptastic camera.
Here's one of several attempts without a flash, the only 'successful' one. Kept giving me error messages and if it has an error, it won't take a picture. A good smack and it decided to take a picture, albeit a blurry one. This is to give an idea of the ambient lighting.
With flash. Removable floor mats are very dirty but that's what they are there for, to keep that dirt off of my carpet and the rest of my truck.
That's it for now. Nothing really major planned anytime soon.
-Dan
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group. Color scheme by ColorizeIt.
